| diyAudio Sponsor | ||
A sometimes-used topology involves a LTP with CCS in the tail, but with the addition of feedback from both anodes to the CCS. The earliest example I saw is in Curcio's '89 article in GA for his cascode LTP.
The idea is to further balance the LTP by taking signals from both plates through a summing junction and applying it to modulate the CCS. Curcio's CCS was a simple 1-transistor affair and presumably not real stiff. That may explain the usefulness of this feedback scheme. However, a modern, very stiff CCS doesn't need any help to balance the LTP. So, would you still use this feedback feature? What for? Increased CMR? Anyone currently using it, or designing with it, can you comment? |
#2 |
Yes, CMR is the big deal. You can improve it in Curcio's circuit by running a battery (or string of batteries, you want 80V or so) between the cathodes of the bottom tubes and the grids of the top tubes. I changed out the bottom tubes for FETs (2N5566), then used a 9V battery between cathodes and grids.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Is there really any AC-feedback? The AC at each anode should countertact each other in the junction between the two resistors going to the PNPs base.
Brgds Lars |
#4 | |
www.kta-hifi.net |
| Help for LTP/CCS plus cathode follower | karsten21 | Tubes / Valves | 12 | 7th February 2010 07:46 PM |
| Negative LTP CCS supply | Klimon | Tubes / Valves | 14 | 18th March 2009 12:06 PM |
| 12at7 LTP CCS | wicked1 | Tubes / Valves | 11 | 23rd April 2008 08:28 AM |
| Tube LTP CCS? | kegger | Tubes / Valves | 23 | 12th August 2006 01:03 AM |
| Page generated in 0.10235 seconds (71.63% PHP - 28.37% MySQL) with 10 queries |
