diyAudio Sponsor
Old 23rd September 2011, 12:47 PM   #1
Troncones's Avatar
Default 5V Indrect Heated Rectifiers?
I like the idea of the slower start of indrect heating. The 5AR4 is the main stream tube like this. Are there others that are suitable for class A Hi-Fi applications? Regardless of plate current rating.
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 23rd September 2011, 12:49 PM   #2
Frank Berry's Avatar
5V4
Frank
Old 23rd September 2011, 02:59 PM   #3
5Z4 is another one, but a number of designers have used damper tubes in pairs. They have the advantage of high current and high peak voltage.
Old 23rd September 2011, 11:14 PM   #4
GZ33, GZ37
Old 24th September 2011, 12:24 AM   #5
The 6087/5Y3WGTB and the 6106 are 5Y3 variants with cathode sleeves.
Eli D.
Old 24th September 2011, 06:28 AM   #6
Tfan69 is offline Tfan69  Italy
Tfan69's Avatar
btw 5AR4 is a direct heating rectifier..
Old 24th September 2011, 07:35 AM   #7
Not in my book.
Old 24th September 2011, 07:52 AM   #8
Blaireau's Avatar
"btw 5AR4 is a direct heating rectifier.." 5AR4 - GZ34 is an indirect heated tube. http://frank.pocnet.net/sheets/093/5/5AR4.pdf
http://constructions.f6fkn.com
Old 24th September 2011, 08:05 AM   #9
Vinylsavor's Avatar
Hi!
That's correct the 5AR4 has an indirectly heated cathode. It is often confused with the directly heated variant since the cathode is internally connected to the heater at one side. Sometimes this is referred to as 'half indirect'. But technically speaking the cathode is indirectly heated.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 24th September 2011, 11:08 AM   #10
Couple more :- GZ32 / 54KU GZ30 / 5Z4 / R52
5v to 2.5v for 2a3 filament gasser-dude Tubes / Valves 7 13th February 2010 09:18 AM
Heated Mouse? Sch3mat1c Parts 22 22nd February 2004 11:31 AM
Can you make 0-5V DC out of 2.5-0-2.5V AC Ralph Tubes / Valves 17 23rd September 2003 03:20 PM
Page generated in 0.09319 seconds (74.09% PHP - 25.91% MySQL) with 10 queries
