I just setup my mimiwat n3 with a pair of Energy cb-20 speakers
Old 23rd September 2011, 03:16 AM   #1
jerrynsr is offline jerrynsr  United States
Default I just setup my mimiwat n3 with a pair of Energy cb-20 speakers
wow! The energy cb-20 speakers sensitivity is 92db. My miniwatt n3 in the bedroom upstairs sounds better than my 26 year old Kenwood driving a pair of JBL 350s downstairs (I bought the Kenwood when I was 20 years old)
First tunes were Van Morrison "Precious Time" , "Domino" then some Bruce Springsteen "Tenth Avenue Freeze Out" I play sax... The sax never sounded like this when I played these tunes on my Kenwood. I am gonna listen to my blues collection on this tomorrow night. I can't believe the sound imagery, stuff that you couldn't hear through a decent quality solid state amp comes alive through this small single ended amp! Now I am saving for a tube amp to replace the old Kenwood.
Old 23rd September 2011, 03:51 AM   #2
dabbler is offline dabbler
Originally Posted by jerrynsr View Post
..I can't believe the sound imagery, stuff that you couldn't hear through a decent quality solid state amp comes alive through this small single ended amp! ...
I bought an N3 recently on ebay and was also surprised by the diffuse and "larger than life" sound stage artifacts. Its the first time I heard sound coming WAY outside the confines of my speakers location and instruments sounding bigger than they really are. Its not exactly accurate but a neat trick all the same. Does anyone know how an amplifier can create such an effect?
Old 23rd September 2011, 01:37 PM   #3
Default It's not trickery. I believe solid state amps filter out some of the actual recording
I believe what actually is happening is solid state amplifiers have more filtering in order reduce hiss and wine. Tube amplifiers don't have that, the result is you hear more of the actual recording. For instance I listened to a live recording of
Jeff Healy play "I'm Torn Down" from the Mess of Blues album.. wow! You can hear the stage presence! I also listen to this on my old kenwood and it don't sound nearly as good. From what I've experienced so far I'd say tubes are better suited for music than solid state. There is a market for this. Especially since even an affordable tube amp sounds much better than an solid state amp consting 4 times as much!
Old 23rd September 2011, 05:09 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Within its power expectations i would fully expect the miniwatt to out perform the old Kenwood sonically.
Now you need to look at getting some speakers that really complete the miniWatt
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd September 2011, 05:42 PM   #5
I think I found the pair. the Energy CB-20s really sound great! Bar Room Boogie
(Jeff Healy, Stevie Ray Vaughn, B.B. King, Muddy Waters, Buddy Guy) wow.. sounds incredible. I'm going to take out my old vinyl tonight and test with my old Technics turntable that I purchased when I bought the Kenwood 26 years ago.
7 watts never sounded so good
Old 23rd September 2011, 07:12 PM   #6
frugal-phile(tm)
planet10's Avatar
2x3.5 Watt is normally how that would be speced
dave
Old 23rd September 2011, 07:30 PM   #7
Default My speakers and output transformer connection is at 4 ohms.
The N3 has banana plug connections for 4,6,and 8 ohm outputs.
My speakers are 4 ohm speakers. The amplifier is 2x3.5 @ 8 ohms.
with a 4 ohm load I've got 2x7w
Old 23rd September 2011, 07:45 PM   #8
frugal-phile(tm)
planet10's Avatar
Plugged into the 4, 6, or 8 ohm taps it will still be 2 x 3.5 w. if the speaker deviates from the tap rating power will decrease.
dave
Old 23rd September 2011, 08:02 PM   #9
Default The speaker resisitance has everything to do with available power from the amplifier.
The ohm is the unit of measure for impedance, or electrical resistance. What does this have to do with your amp? It affects how much power your amplifier produces. Power = voltage^2/resistance. Anything that is fed an electrical signal provides resistance. The higher the number in ohms the higher the resistance. Many loudspeakers are rated at 8 ohms. This rating is usually listed as “nominal” because resistance changes over the frequency range. It is usually not too high resistance that we have to worry about, but too low resistance. Say you have an amp that will produce 25 watts (power) into 8 ohms. If you show the amplifier a 4 ohm load, you decrease resistance and increase power because any given number will be larger when divided by a smaller number (80/8 < 80/4). As the resistance decreases and power will increase (a theoretically perfect amplifier would double in output) the current will also increase because Ohm’s law states that current = voltage/resistance (power = voltage^2/resistance). If the amp has the capability to produce this much current and dissipate the heat, you will be fine, but if not, you will over heat the amp and may ruin it or at the least trip the protection circuitry. You should always know the limits of your speakers and amplifier to avoid damage.
I am sure that when I measure the signal with my oscilloscope across a speaker I will see @ 7watts rms and @ 10Watts peak.
Old 23rd September 2011, 08:08 PM   #10
kevinkr's Avatar
Nope, you got 2 x 3.5W, the output voltage scales as the square (root) of the impedance ratio of the taps. Tube amps need to matched to their load so that the output tube sees a certain impedance for optimum performance - so each tap on on the OPT is calculated to reflect approximately the same impedance to the tube's plate for its intended speaker impedance. Tube amps have a relatively constant maximum output capability that is relatively independent of load impedance since the load is matched to the output stage. (Albeit inflexibly)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
I just setup my mimiwat n3 with a pair of Energy cb-20 speakersHide this!Advertise here!
FS pair of Energy 22 Reference Connoisseur speakers Octavious Swap Meet 4 30th June 2011 06:55 PM
Wanted to Buy: Pair of Energy 22 Tweeters dtm1962 Swap Meet 4 24th June 2011 03:37 AM
Looking for a Pair of Energy Veritas V2.8 8" Woofers dtm1962 Swap Meet 0 30th December 2009 02:24 AM
IC: Energy C-1 speakers xstephanx Swap Meet 1 11th July 2006 03:28 PM
Brand New Energy C-3 bookshelf speakers The Paulinator Swap Meet 0 3rd May 2006 02:29 PM
