| diyAudio Sponsor | ||
Friends
Anyone have the russian 6P8S datasheet ? Thanks, Aldovan |
#2 |
Can't find normal datasheet just now, but it's a version of 6P6S (6V6) designed for TV use. Quite rare, BTW.
So in general it's something from the 6V6/6F6/6W6 glass family. |
#3 |
i found a mention it might be close to 6u6GT
#4 |
#5 |
its most likely just a slightly modded 6v6 i wouldt think those penny snatchers would ever make something uniqe for vertical deflection . hell yeah i think its a 6v6 rated for pulsing whit reduced lifetime check the sheet though i havent
if connections and important parameters are the same its just specced differend |
#6 |
After further investigation it turned out that 6P8S (previously marked as 6I6S) is really a Soviet clone of 6U6GT.
So its plate is rated at 11W and 200V max. |
#7 | |
Thanks ! Them the pins connectin are the same of the 6U6GT ? Is possible find the datasheet in the internet ? I do not can find in russian or english. Thanks, Aldovan |
#8 | ||
You can use 6U6GT datasheet, I believe. |
#9 |
I think the parameters close 6P1P .
#10 |
Friends
I will make some experiences in triode mode and post here. I like russian tubes, many times forgetten russian pentodes tubes sound very good in triode mode. Thanks to all friends !!! Aldovan |
| Datasheet | shon35us | Chip Amps | 3 | 9th March 2009 03:10 PM |
| Looking for datasheet | satelitis | Tubes / Valves | 3 | 9th December 2005 08:20 PM |
| Datasheet help | Stocker | Parts | 0 | 10th March 2004 01:36 PM |
| Datasheet | Piersma | Digital Source | 3 | 29th January 2003 07:49 PM |
| Need datasheet | Michael_N | Digital Source | 5 | 21st January 2002 11:07 PM |
| Page generated in 0.10297 seconds (81.94% PHP - 18.06% MySQL) with 10 queries |
