| diyAudio Sponsor | ||
Hi all
I am actually sourcing the parts for the Pete Millett Engineering amp. As I am working in a company which also has a small production for High End Audio, I would have the possibility to get two output transformers custom made by our audio department (Nagra Audio). But they need the details to produce the transformer (windings, size etc...) The problem is that I have nooooo clue on how to calculate a torodidal output transformer... What I know is this (the original design uses EDCOR iron) - Input impedance: 8k - Output impedance: 8Ohm - Power: 25 Watts Is there anybody who knows how to calculate the specs for this transfomer ? Or is there a software which lets me calculate it ? Best regards Christoph |
#2 | |
frugal-phile(tm)
Personally i'd be leaning on the expertise of the guys in the winding dept. I'm sure they have their own bag of tricks that make a Nagra OPT a Nagra OPT. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
hi dave,
tricks probably yes, but they want from me the number of windings :-( and the core dimension)..... bad luck.... take care, Chris |
#4 |
Have a chat to Yvesm on this Forum.
He has a little tool I'm sure he will licence to you to design up Transformers.... I say, 'Licence' as you're a Commercial entity.....
Das Beste Oder Nichts |
#5 |
Hi
Thanks for the hint. Unfortunately I am not a commercial entity, I just work for the same group, but in another company. And I am a network Engineer, doing audio "stuff" just as a hobby... Otherwise I would not have this kind of question ;-) Best regards Christoph |
#6 |
In which case, He'll prob be happy for you to use it with no licence...
Give him a shout anyay, explain the situation....
| Shorted secondary windings of transformer | Edvard | Tubes / Valves | 5 | 29th December 2010 10:22 PM |
| Transformer Windings | impsick | Chip Amps | 6 | 2nd February 2007 11:00 AM |
| transformer primary windings Q | AndrewT | Power Supplies | 6 | 28th October 2006 11:51 AM |
| Transformer windings identifications - how to get it? | Alfetta87 | Solid State | 7 | 21st February 2005 04:01 PM |
| opt windings, need some help | jazz | Tubes / Valves | 13 | 7th November 2003 02:50 PM |
| Page generated in 0.08510 seconds (74.54% PHP - 25.46% MySQL) with 10 queries |
