diyAudio Sponsor
Old 20th September 2011, 01:41 PM   #1
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
Default How do they get away with this?
I'd like building compact amps and preamps but it always worries me the distance between the power transformer and the signal circuit (SMPS may be an option, haven't tried that yet). So when I see something like this I wonder. Is it enough a metal screen around the tube? I really don't understand how they can get away with that PT so close to the inputs. But it seems it can be done. Is it because that is a buffer stage? I have a small torodial PT and my guitar preamp circuit has quite some gain. Would it be a waste of time to try something similar? Any tricks? I have also seen people using metallic mesh screens (2nd pic). What works best?
http://www.hdmag.dk/valvulator.jpg
Old 20th September 2011, 03:23 PM   #2
Cassiel's Avatar
Oh well, I have read the manual.
The custom
power transformer is ruggedly built to withstand years of road
abuse. It features a low noise design that allows for installation
in tight quarters and close proximity to other devices with
minimum hum and noise.
So there's hum and noise. No big surprise after all. So I'm narrowing down my questions. No mu-metal here so what's best to isolate the trafo? Copper, aluminium or steel? Solid or mesh? Maybe I should use the search bottom...probably this has been asked before.
Old 20th September 2011, 03:35 PM   #3
Merlinb is offline Merlinb  United Kingdom
A screen like that can only shield against electric fields, not magnetic ones, so the type of metal is immaterial (geddit?!).
Solid or mesh, it doesn't really matter since we're working at low frequencies.
Old 20th September 2011, 03:42 PM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Mu metal will help, however bending it changes it's characteristics. Proper shields are made to shape and then heat treated by taking them above the critical temperature (currie point?) and cooling them at a rate to optimize their shelding properties.
Old 20th September 2011, 03:45 PM   #5
Joschl is offline Joschl  Germany
I guess the metal screen around the tube in the first picture is only against heat radiation to the electrolytics.
Old 20th September 2011, 04:10 PM   #6
Cassiel's Avatar
Originally Posted by Merlinb View Post
(geddit?!).
Affirmative, over and out.
Old 20th September 2011, 04:24 PM   #7
Pano is offline Pano  United States
Pano's Avatar
Please be kind to your fellow forum readers of limited bandwidth. Don't include inline photos of 1.4 Meg
Please see this thread: Pictures -- Why Not attach Them ??
Old 20th September 2011, 04:28 PM   #8
kevinkr's Avatar
And not so limited bandwidth, even here at work it took 30 seconds to load and I had to resize it in firefox so that the thread displayed properly..
www.kta-hifi.net
Old 20th September 2011, 04:29 PM   #9
Cassiel's Avatar
Sorry for that. That photo grows all by itself....it wasn't that big. You can delete it if you want to.
Fryette Vavulator (Tube Buffer/Special Sauce))
Old 20th September 2011, 05:26 PM   #10
markusA is offline markusA  Sweden
Interesting dilemma that I've wondered about myself.
Page generated in 0.10908 seconds (82.24% PHP - 17.76% MySQL) with 10 queries
