| diyAudio Sponsor | ||
It has started popping, and I believe mouse pee may at least partly be the problem, as when I pulled it apart I found significant rust spots all over the chassis and many seeds, poop pellets, and nest artifacts fell out. I cannot see any shorts w/ the lights out. I isolated the popping to one channel though by pulling a tube but, curiously, it affects both channels.
I will blow it out with high pressure air (120 lbs), but I am wondering if there is a solvent to use to get ionic precipitates out. Notes on the stereo Sherwood (said to be last tube stereo): This the amp that turned me around. I got it from the trash for its aesthetics, but, as it warmed up to an old MJQ record, even my cat got excited. W/ two Yamaha natural speakers (also from the trash) it is if the long-gone quartet is in the room, but interestingly only w/ tube-recorded records (from ebay). I cross point two "tinny" satellite speakers at the naturals to cancel out undesired noise, and the sound gets even deeper. Amazing, why did we ever change? |
| The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter | River757 | Multi-Way | 14 | 7th September 2011 06:41 PM |
| 31 Band Equalizer "the t.eq" "TQ-60" schematic wanted | tiefbassuebertr | Solid State | 2 | 29th March 2010 03:45 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Yaqin mc10l "popping" | Reg Stir | Tubes / Valves | 5 | 5th August 2008 04:43 PM |
| PC wireless mouse goes "bang" still works | Rixsta | Everything Else | 2 | 20th May 2004 09:15 AM |
| Page generated in 0.06732 seconds (65.28% PHP - 34.72% MySQL) with 10 queries |
