| diyAudio Sponsor | ||
I have some 16458 outputs that I would like to use in an amp project. I think the primary is 6600ohm. Would they work in a PP- 6B4/6A3 amp?
Any other suggestions or schematics greatly appreciated. |
#2 |
Lug -- From a point of accuracy for any project you use these transformers with, they are 9000 ohm plate-to-plate primary impedance transformers, with the screen taps located at 50% of the winding. Good for 25 watts RMS 20 Hz to 20 kHz. They are excellent transformers indeed!
Dave |
#3 |
Dave, thanks for the info! Any thoughts on a 6B4/6A3 amp project?
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| linear and TOPSwitch transformers, peerless 6.5" mids | Evan Shultz | Swap Meet | 0 | 8th November 2005 05:59 AM |
| Output Transformers | eduardio | Tubes / Valves | 2 | 13th May 2005 02:42 PM |
| Output transformers | Fuling | Tubes / Valves | 15 | 9th June 2002 12:13 PM |
| Page generated in 0.07066 seconds (70.94% PHP - 29.06% MySQL) with 10 queries |
