| diyAudio Sponsor | ||
Hi all,
Saw this http://www.ebay.com/itm/HIFI-Audio-T...item3a69a3ea41 recently online and wondered if anyone had built it. The cost is pretty reasonable (US$235) as is postage to get it to me. I've queried the seller and I'm waiting on a copy of the schematic, but whilst I wait, any thoughts? Last edited by aspringv; 19th September 2011 at 07:53 AM. |
#2 |
That was quite quick! FYI I'm not associated with the seller in any way, I'm just looking to get informed feedback before I consider a purchace.
#3 |
Tinkerer
Output is a pentode without any feedback, either local or global? Highly not recommended by any expert... BUT, you can triode connect it with a slight modification, and get 4 - 5 watts, which may or may not be enough for you.
#4 |
Cool thanks. Power's not a major issue, and I guess in the end it's a set of parts and a chassis to suit, and after that I suppose I could make whatever design that I felt like.
Hmm, I'll do a bit more thinking. |
#5 |
depends what you are looking for.
you could try the oatley elec kits (also not affiliated with them - the k281) if you are like me and looking for a bit of experience. oatley are also up nth in NSW so local(ish) to us. also is a smaller investment. depends what you want cheers mate |
#6 | |
Suppose you build it yourself not with a kit : If you buy all those Shuguang tubes brand new on eBay, you will paid about 80$ If you buy the transformers from Edcor, you will paid about 170$ Figure out 10$ for the sockets, 20$ for the frame, 20$ for the volume pot, 10$ for the plugs, 30$ for all the resistors and good capacitors, 20$ for different hardware ... All that cost about 360$, maybe a little less ... Cheers, Alain. |
#7 |
From the cct diagram, it appears the EL34E is triode connected, hence lower output power, I don't think you can get 10W from each channel. the o/p transformer is not an ultra-linear one so you cannot modified the cct diagram to operate in ultra-linear mode, in this mode you can get about 12Watts. If you are interested in this type of amp try this site:Shuguang,Shuguang treasure,Fullmusic,Guiguang tubes,amplifier chassis,tube sockets,capacitor,resistors,coil meters,toggle switches,tag boards,transformer covers,various parts for tube guitar amps diy <meta name="keywords" content="tube sockets,shugua look under vacuum tube amplifier heading, model GDAP 01. I bought a unit. the o/p transformer is ultra-linear type. For the money I am quite happy with it but it is not operating in its ideal state, I have to modify it to apply operate feedback to the cct. BTW I am not associated with the company. |
#8 | |
With a 340 ohms cathode resistor, the bias most be very high and there will be more than 10% distortion at full power for sure ... And there is no feedback to attenuate it ... I also notice the voltage of the screen grid is higher than the plate voltage because the voltage drop in the primary of the output transformer ... It suppose to be equal or lower ... All that is a bit suspicious but you can modify it to get a better sound, but less power. The 6CA7 / EL34 have a separate suppressor grid from the cathode, it can be reliate to the screen grid and plate to make "a real triode connexion" ... The power will be much less but the distortion too. Cheers, Alain. |
#10 |
| $75 tube amp kit on eBay??? | jmillerdoc | Tubes / Valves | 7 | 26th August 2011 07:08 PM |
| a CHEAP integrated tube amp kit-anybody? | namatjira | Tubes / Valves | 0 | 15th March 2008 02:22 AM |
| Page generated in 0.12608 seconds (79.62% PHP - 20.38% MySQL) with 11 queries |
