#71 |
OK, but the safety ground should go right to the chassis near the IEC plug.
Measure voltages for us to check. |
#72 |
I've (only just) started having a play with RMAA and thought I'd throw this amp on for testing. The load was a 4.7R wirewould and ally housed and the terminal on the amp used was the 4 ohm one.
Results below. |
| $75 tube amp kit on eBay??? | jmillerdoc | Tubes / Valves | 7 | 26th August 2011 07:08 PM |
| a CHEAP integrated tube amp kit-anybody? | namatjira | Tubes / Valves | 0 | 15th March 2008 02:22 AM |
