#31 | |
The disadvantage of using local feedback around a preamp tube is that (1) you loose bragging rights on saying how the mega-expensive and rare NOS tube sounds because with local NFB that all are near perfect and (2) the common cathode stage is less stylish but my opinion is that fewer parts (especially tubes) the better About hum: wait until you are all done. First build the amp using 6.3 volts AC heaters. Yes do the easy thing and elevate the heaters to at least match the power tube cathode. Then listen. Good chance it will be silent. But if not the first test is to run the heaters using a BATTERY. Nothing is more quite. Make an A/B switch and flip between AC and battery. If this solves the hum only then go for DC heaters. But there is a good chance that hum is in the B+ power or magnetic coupling from PT to OPT or even a microphonic preamp tube picking up 60Hz vibration from PT. The battery test will help sort that out. |
#32 |
Just checking in here....(I'm away from my home base)....
That amp (in the thread Building something better with a Chinese SE EL34B Amp DIY Kit turned out pretty well, IMO. Sounds fine driving ~95dB AudioNirvanas. Have fun! (It was my one-and-never-to-be-repeated amp with a stainless chassis.) John |
#33 |
OK then, well, I'll hang fire till the kit arrives and then I'll photograph it, build it, run some measurements and get back to the forum for some tweaking help.
Cheers all, and I'll repost in a coupla weeks! |
#34 | |
I also believe fewer parts is better and capacitors are not very good for the sound, using just high gain triodes like the 12AX7 can compensate for the lack of gain caused by the feedback ... I am not crazy about using penthodes in preamplifiers stages, but if it is better than two triodes stages, why not ...
#35 | |
#36 |
Rather more swiftly than I would have expected, the kit has arrived. I quick summary of my feelings during the unboxing experience would be 'mixed emotions'. A few pics here https://picasaweb.google.com/aspring...eat=directlink
for any who are interested to have a look at. https://picasaweb.google.com/lh/phot...eat=directlink The transformers made a mess of the box they were in but appear to be undamaged and pleasingly hefty, so I'm naively hopefull that they're adequate to the task. If there's any tests that anyone can propose to me to check em, please let me know. The tubes are a bit dodgy though! The EL's are a new pair, but the 6n9p's are clearly different and one is potentially a used item. The rectifier is definitely 'pre loved'. I've a pair of 12ax7's here in a spares box, so perhaps a redesign utilising these in the future will be in order. The power switch made me laugh - the label for it reads 'on ' and 'on' apparently they work their amps 24/7 in china... ![]() The caps are ok-ish. The two 220uf/100V ones are salvaged from somewhere, but the rest are new... If not of the the values in the schematic. However they are appropriate to use in the given circuit. Then there's the missing parts. Some resistors, 4 speaker posts, and that's about it! I'll be sending off a complaint about the used parts given the item is described as 'brand new', and with regards to the missing bits. Hope that's interesting to everyone! Last edited by aspringv; 6th October 2011 at 12:57 PM. Reason: clarity and brevity are the soul of good communication. |
#37 |
I'll repost them at a later point in smaller size...
#38 | |
#39 | |
How was the chassis? i.e. does it match up with the transformers? Have fun!
#40 |
LOL, for a moment I thought the chassis was made from cardboard.
Doh! https://picasaweb.google.com/aspring...30885357169874 Silly me
| $75 tube amp kit on eBay??? | jmillerdoc | Tubes / Valves | 7 | 26th August 2011 07:08 PM |
| a CHEAP integrated tube amp kit-anybody? | namatjira | Tubes / Valves | 0 | 15th March 2008 02:22 AM |
