diyAudio Sponsor
Old 18th September 2011, 04:05 PM   #1
Troncones's Avatar
Default Rectifier Foward Voltage?
Eli made a statement about a rectifier having a lower foward (on) voltage. I can't find my way back to the thread it was in. I have looked at several data sheets for rectifiers and haven't spotted it.
Where can this info be found?
When calculating PS ripple where does this data fit in?
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 18th September 2011, 04:43 PM   #2
DF96 is offline DF96  England
It may be given in graphical form: voltage vs current.
It only has a small effect on PSU ripple. The main issue is current drawn vs. reservoir cap value, then any smoothing which follows.
Old 18th September 2011, 09:27 PM   #3
cogsncogs's Avatar
Some data sheets, like one for a RCA 5V3A, will have it under
Typical Operation:
AC Plate to Plate Supply Voltage
and so forth...
Characteristics: Tube-Voltage Drop for plate mA. = 350mA
Per Plate.....................42 volts
Some data sheets will have listed as such, others will be as DF96 stated in graphical form or both.
Old 18th September 2011, 09:45 PM   #4
Isn't rectifier's plate resistance pretty constant within it's operating limits? So if the datasheets say it drops 20volts @ 100mA the plate resistance is 200ohms, and you can then calculate the voltage drop at other load currents.
Old 18th September 2011, 09:48 PM   #5
Its not that linear. Check out the graph on page 5 on this link for the GZ34. http://www.r-type.org/pdfs/gz34.pdf
Old 18th September 2011, 09:55 PM   #6
An ideal thermionic diode will have a 3/2 power law, so I~V^(3/2). Real diodes follow this law only approximately.
Old 19th September 2011, 04:09 AM   #7
Miles Prower's Avatar
Spec sheets, and the plate characteristics as shown here. (attached) What they're calling "plate voltage" is really plate-to-cathode voltage, and therefore, forward voltage.
It doesn't.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 22nd September 2011, 02:59 PM   #8
Troncones's Avatar
Thanks Everybody
Dropping rectifier filament voltage Nightpuma Tubes / Valves 13 2nd February 2009 10:55 AM
Rectifier Capacator (voltage adjust) wicked1 Tubes / Valves 10 15th January 2009 05:48 PM
rectifier voltage drop dsavitsk Tubes / Valves 8 10th November 2006 05:52 AM
Rectifier voltage difference, Why? Original Burnedfingers Tubes / Valves 15 16th January 2006 12:46 PM
Page generated in 0.10511 seconds (75.89% PHP - 24.11% MySQL) with 11 queries
