Help with these Russian GU50 tube amplifier - Page 7 - diyAudio
Old 13th March 2012, 04:39 AM   #61
albertli's Avatar
Originally Posted by Wavebourn View Post
With 400V on anode don't be afraid to connect G2 directly to anode. It is not voltage that damages the screen grid, it is power. When voltage on the screen grid is fixed and voltage on anode goes down screen grid starts pulling more current and can be overheated and damaged. But when it is tied to anode it is safe to drive both anode and g2 up to 800 volts, in this case you have to watch for anode dissipation that must not go beyond 40 Watt. However, due to material used for anode it can dissipate 100+ watt shortly, but you can't run it in such regime for a long time.
Wavebourn,
Thanks for your advice. I've made correction on the schematic. Please take a look and comment.
Do I have to care ground the pin 7 ??
Will the drivers work fine ?? anything make change to improve ??
Albert
Old 13th March 2012, 05:44 AM   #62
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by albertli View Post
Wavebourn,
It looks fine. Pin 7 is screen between electrodes, it is better to ground it. Also, you may keep that resistors in screen grids as stoppers to avoid possible HF oscillations.
Both Sergeev's and Globulator's schematics look nice.
Oops... I meant Artosalo's schematic that Globulator commented, sorry.
The Devil is not so terrible as his math model is!
Old 13th March 2012, 06:47 AM   #63
right handed triode mode
Hey,
Havenīt heard that expression before.
Globulator uses a tetrode in anodefollowermode(Schade) with Zin of ca 5k.
Old 13th March 2012, 08:20 AM   #64
Hello
May I ask why you use 6V6 as a driver. 6V6 mostly used as a power tube, I don't say it cant be used as a driver. I sow schematics were 300B drive GM70 tube but extra $$$..
I think 6SN7 if used both side can drive one chanel (two GU50) probably would sound better.
I would be interested on that.
Wavebourn has some schematic if I remember with out coupling caps. That would be very interesting unfortunately was not tested yet.
Greetings Gabor
Old 13th March 2012, 09:10 AM   #65
Using a 6V6 as CF before the GU50 is wasted when not directcoupling it like Artosalo did. Also a 6SN7 will not have gain enough as single driver.
If going for a pentode input it should be with something more linear and high-Gm than the 6AU6.
Old 13th March 2012, 10:39 AM   #66
Wavebourn's Avatar
Originally Posted by revintage View Post
Hey,
Like 811, when grid is driven positively, when you connect all grids together.
www.wavebourn.com • View topic - GU-50 Single Ended Amplifier Design
Old 13th March 2012, 02:45 PM   #67
albertli's Avatar
[QUOTE=Wavebourn;2943918]It looks fine. Pin 7 is screen between electrodes, it is better to ground it. Also, you may keep that resistors in screen grids as stoppers to avoid possible HF oscillations.
Wavebourn,
So I join pin 1 & 7 together and through the resistor to ground. Am I correct ???
Albert
Old 13th March 2012, 02:58 PM   #68
jane is offline jane  Norway
jane's Avatar
I'm not sure that the CF will pull 20mA in this configuration. At 20mA the voltage over the cathode resistor would be 44v (20mA x 2k2) and the 6V6 will cut off..
Life is hard - Then you die.
Old 13th March 2012, 03:10 PM   #69
Wavebourn's Avatar
Right.
Old 13th March 2012, 03:46 PM   #70
Wavebourn's Avatar
My bad, I did not mention that.
Of course, the amp would be very suboptimal. But punched holes for tube sockets will be a good step ahead. After discovery that voltage swing is not enough to drive Gu-50 he would think how to improve things. I assume from this point real understanding would sprang, leading to first hand experience. However I taught Pascal language on chalkboard simulating response, but it was because hardware was not available then. Curiosity is the thing that drives us to explore details. "Why it happened?" is better question than "Is it perfect?" Nothing is perfect. But as soon as I start feeling of character and behavior of some active component, schematic diagram, I started getting control on it. Sometimes the first step is the hardest one, "How to start?" Actually, it boils down to, "If I start it this way, how close it will be to the perfect solution"? This question stops my projects often, putting brain in endless loops. That's why I have so many unfinished projects. And it would be much better if somebody encourages me, "Do it, try, measure, ask, and we'll help to improve".
You know, what stops my further learning, my experiments? Internal dialogue: "Wait, what if it is not perfect yet?"
But it is a good point, to work on a driver. How much voltage and current swing we want from it, then how to implement it.
Tube SE amplifier with 6P3S (russian tube) danzup Tubes / Valves 48 6th June 2013 04:51 PM
Copyright Đ1999-2017 diyAudio
