Help with these Russian GU50 tube amplifier
Old 18th September 2011, 05:33 AM   #1
gaborbela is offline gaborbela  Canada
Default Help with these Russian GU50 tube amplifier
Hello
I like these amplifier a lot.
But because is posted in Russian website even if I translate with translator hard to understand everything.
It would be stupid to start a project and I do not understand all.
Однотактный усилитель на ГУ-50
I would like to ask some help from Russian DIY-ers.
Even at the schematic some writing I do not understand.
Also there is some type of transistor, I don't know what type or part number.
Also I attache the schematic.
If I understand well the 420V goes to left chanel and right chanel
Also the bias goes to left chanel and right chanel BUT on the schematic each chanel has two bias- do I have to connect that two together??
There is 30V at the PS, I have no idea where it goes.
Any help it would be great , otherwise I have to look for other GU50 project.
These would be great with the 25W Edcor OP transformer.
Thank you very much
Greetings gabor
Old 18th September 2011, 08:43 AM   #2
Timofey is offline Timofey  Russian Federation
Timofey's Avatar
"Transistor" is Filter+delay turn on circuit.
See attach UZF
Yea, you are right.
Yes, you have to connect bias inside of each channel together. Also bias for channels separated.
+30V applayed to filaments for AC "Hum-m-m!" noise cancellation. Just solder together points "A" on PSU schematic.
Old 18th September 2011, 09:43 AM   #3
Jaap is offline Jaap  Netherlands
Jaap's Avatar
What is the impedance of the OPT ?
Old 18th September 2011, 10:45 AM   #4
Timofey's Avatar
3200-3300 Ohm / 8 Ohm
Old 18th September 2011, 10:55 AM   #5
Timofey's Avatar
I'm sorry, that PSU schematic for 1xGU50 per channel.
For 2 tubes in parallel needs (22 k pot + 10 k resistor + capacitors) for separate trim bias each tube in channel.
Old 18th September 2011, 11:51 AM   #6
costis_n is offline costis_n  Greece
I have great respect for Russian DIY, but I see some issues with this schematic.
- Max G2 Voltage for GU60 is 250 V
- No grid stoppers anywhere, and especially no G2 stopper in the GU50's
- Surely is 6e5Π enough to drive 2X GU50 grid capacitance in triode?
Old 18th September 2011, 12:52 PM   #7
artosalo is offline artosalo  Finland
artosalo's Avatar
In triode connection 400 V is allowed (according to original LS50 specs.)
Why not ?
µ of GU50 in triode mode is only some 5,5, so the Miller-capacitance is quite low. The output impedance of 6e5p seems to be about 10 kilo ohms only. No problem.
Old 18th September 2011, 04:08 PM   #8
quikie22 is offline quikie22  Malaysia
Agree with arto. Have built another amp with 6e5p and gu-50. It gives a very clean and detailed sound. Mine is cathode bias instead of fixed bias. But I run both in pentode mode but with local feed back.
Old 18th September 2011, 04:12 PM   #9
My question was about triode mode, where there are the limitations I asked about.
Old 18th September 2011, 04:20 PM   #10
Dunno why my post came out twice. Typing off a smartphone seems to give a variety of problems.
Anyway I tried with 6e5p driver into gu50'triode too. It works very well and sounded excellent on my foster high-eff horns. Unfortunately I needed extra power to feed my 89db kef speakers hence the switch to pentode.
Help with these Russian GU50 tube amplifierHide this!Advertise here!
Tube SE amplifier with 6P3S (russian tube) danzup Tubes / Valves 48 6th June 2013 05:51 PM
Copyright ©1999-2017 diyAudio
