Help with these Russian GU50 tube amplifier
>>>> There is 30V at the PS, I have no idea where it goes.
+30V applayed to filaments for AC "Hum-m-m!" noise cancellation. Just solder together points "A" on PSU schematic.
Hello
Would you be so kind please help me with these +30 on the PSU circuit.
I do not have center tap (or A point) at 6.3V and 12V heater..
Where I connect the +30 in my case or just leave it out?
Please take a look at my parts I have for these amp PSU!
I also purchased a par OPT 3.5K 10W 100mA continuous bias.. Al together I have 90-95% of the parts.
I would love to test the amp but with that +30 I don't know what to do..
The 12V for the GU50 is a separate transformer also I have DC PSU for the GU50 if that is better all do that is only 2A the AC is 5A.
Greetings Gabor
Hello
Greetings Gabor
You do not need this.
Look: http://www.diyaudio.com/forums/tubes-valves/211731-heater-wiring-good-bad-ugly-7.html
post 69. It is really works.
