| diyAudio Sponsor | ||
I by chance aquired several Mullard PZ30. They look like beefy full-wave rectifiers, with large cathoded and exaggerating plates, in comparison with the common GZ34 alike. TDSL site says that it can handle roughly 200mA but not indicating the PIV. Does anyone know its PIV or more detailed info about it? Thanks a lot.
#2 |
#3 |
Thanks. But it has mentioned anything about the PIV.
#4 |
Pls. look in the RDH4, p. 1177 (Chapter 30.2 vi.)
Andreas |
#5 |
Many thanks. It seems that it doesn't appear in the table at the bottom of the page. In fact I want to build a bridge, so I need to know PIV to judge how hight the maximum RMS supply voltage could be. Usually in full wave rectifying mode this tube can only accept approximately 240V RMS at most with condenser input But as we know, for full-wave rectification, the PIV appear at both ends of the diode is roughy 3.14 times of output DC voltage, and but in bridge is 1.57 times, which means in bridge topology, it can be used to accomodate higher RMS input and yield higher DC voltage. But the key here is how much is its PIV so headroom can be arranged for its safe operation.
#6 | |
![]() Disclaimer: never rectify mains voltage kids. It's hideously dangerous. |
#7 |
Yeah. I will prepare a separate power tranny for it, other than connecting it directly to the mains voltage. I appreciate its capability to handle large current and the Mullard brand.
| Spect output peak to peak for 807 SE ul | walter807 | Tubes / Valves | 2 | 1st December 2010 11:24 AM |
| Peak Voltage On The Crown 5000vz | OMNIFEX | Solid State | 23 | 10th February 2009 06:06 PM |
| 833a SE Peak A.F. Grid Voltage | dominic_tollens | Tubes / Valves | 4 | 16th June 2008 10:08 AM |
| Diode Peak working voltage ? | mus | Tubes / Valves | 4 | 26th May 2008 04:25 AM |
| Peak voltage output of a Aragon A2D2 DAC? | G | Digital Source | 0 | 16th January 2008 04:54 PM |
| Page generated in 0.09577 seconds (72.64% PHP - 27.36% MySQL) with 10 queries |
