diyAudio Sponsor
Old 17th September 2011, 10:53 AM   #1
CSlee is offline CSlee  United Kingdom
Clueless
CSlee's Avatar
Default Optical compressor project
As part of my research I am looking into optical compressors and have drawn up a schematic to start playing around with in the lab.
At the moment I guess it is just a limiter, but Id love some input on whether this will work before I progress the circuit.
So I guess the questions are, will this work? Am I using the right Vactrol for a compressor? Also, is there any need for a grid leak on the first stage? Any problems with leaving the stages open loop?
As always, all feeback is really appreciated.
Cheers
Charlie
Broke solderer with delusions of grandeur
Old 17th September 2011, 12:13 PM   #2
Frank Berry's Avatar
The diode and LED will produce distortion on the output due to loading.
You may want to use a third stage to drive the LED and isolate it from the CF output stage. You may also want to drive the LED through a bridge rectifier so that it will respond to both halves of the audio waveform.
I've made such a circuit using ICs. It worked very well.
Frank
Old 17th September 2011, 12:22 PM   #3
bigwill is offline bigwill  United Kingdom
Seconding Frank's suggestion - even an opamp would do the trick, in fact it would probably be preferable since you wouldn't have to devote an entire triode section to something that isn't in the audio path
Old 17th September 2011, 12:36 PM   #4
Clueless
CSlee's Avatar
Thanks for the comments.
Just a single transistor or opamp stage followed by another coupling cap?
Cheers
Old 17th September 2011, 12:44 PM   #5
If you use an Opamp and power it with a bipolar supply, you can eliminate the cap on the output of the Opamp.
Frank
Old 17th September 2011, 03:28 PM   #6
richwalters's Avatar
About 25 yrs ago I worked in the audio industry as a designer and photoswitches as analogous devices were quite rife within mixing desks in "non click" cross channel switching applications.
Not sure links work but I know the Vactrol still exists.
Vactrol Analog Opto-isolators
P873 datasheet and application note, data sheet, circuit, pdf, cross reference, pinout | Datasheet Archive
Remember, one will most likely need 2; i.e a series-shunt arrangement as the off capacitance in the series may create bleed through with high impedance circuits.
A Jfet solution: Certainly works but I never got the thd on transition down to an acceptable level which needed a synchronised gate timing circuit to eliminate the worst on the "pinch-off" which can vary by 20%.
Even earlier for organ work, an ORP12 in a tin can excited by a cycle bulb was used.
richy
Old 17th September 2011, 10:47 PM   #7
ruffrecords's Avatar
richy
They are available from Farnell.
Cheers
Ian
Ian
Old 17th September 2011, 10:48 PM   #8
Cheers
Charlie
I would decouple the cathode of the first stage to maximise the open loop gain.
Cheers
Ian
Ian
Old 18th September 2011, 08:40 AM   #9
Clueless
CSlee's Avatar
So a few changes...
Decoupled first stage with a 47uF cap. And a Jfet stage before the diode, just using similar resistor values on the E, C and B? Dont want any gain there do I?
Thanks Richy, if this setup works it will allow me to experiment with different devices.
In my eyes the only way this would be able to be a compressor is if the LED was variable, which it isnt. I did see an old compressor with a bulb in like Richy said, looked pretty cool but maybe a little overkill for these times....
Cheers
Old 18th September 2011, 01:01 PM   #10
In my eyes the only way this would be able to be a compressor is if the LED was variable, which it isn't.
Are you sure about that? Check the data sheets, then look at the VTL5C3 and think about what happens if you change the first 220K resistor to 30K.
Cheers
Ian
Ian
Applying linearising feedback to optical compressor Dr.EM Everything Else 8 8th September 2011 01:23 PM
line to optical ---> optical to analog dirtbiker1824 Digital Line Level 5 27th February 2011 03:29 AM
compressor diy bigredlevy Analog Line Level 8 28th November 2010 06:30 PM
Simple compressor PeteMcK Elektor 4 25th August 2009 01:30 AM
Basic op amp optical compressor questions LarsXI Solid State 0 1st July 2008 11:32 PM
Page generated in 0.10869 seconds (80.22% PHP - 19.78% MySQL) with 11 queries
