12AU7 in cascode configuration - Page 2 - diyAudio
Old 18th September 2011, 12:26 PM   #11
Hey SY,
, actually the sheet didnīt say anything at all. Found the awkward info in a review.
This is my idea how a cascode, if it for some reason must be, should be used:
Old 18th September 2011, 03:51 PM   #12
DF96 is offline DF96  England
If you want 6 or 12dB gain, you don't use a cascode.
If you want lowish output impedance, you don't use a cascode. (NB. in a preamp you will want low output impedance, unless you are incompetent).
If you are serious about valves, you don't hang them out horizontally at the back of the chassis, even with fancy roll-bars. This is asking for poor contact as the valve slowly drops out of the socket, and the risk of 'beverage contamination'.
Old 6th July 2012, 10:34 AM   #13
Tax is offline Tax  Australia
I have a borrowed CF-080LSX preamp in my system. Yes the valves hang horizontally at the back but they use an extremely good socket that has a GRIP on the valve that I have not experienced in any other valve amp before. It is not easy to even 'intentionally' put a valve in a take one out without a bit of brute strength.
Old 6th July 2012, 12:34 PM   #14
This means risk of damage such as glass cracking around the pins. Modern valve bases often grip a bit too tightly.
Cascode Tube Mic Preamp: 12AX7/12AU7 Schematic 88man Tubes / Valves 13 4th August 2012 01:08 AM
12AU7 Amp? thefragger Tubes / Valves 20 8th March 2012 01:26 AM
Better than 12au7? dgta Tubes / Valves 13 4th July 2011 12:32 AM
Preamp tube SRPP 12AU7 VS preamp tube Aikido 12AU7 = all use rec 6X5GT spiritm2r Tubes / Valves 1 6th March 2011 03:53 PM
12AT7,12AU7 Ultra linear cascode ppl Tubes / Valves 33 21st April 2010 07:43 PM
Copyright Đ1999-2017 diyAudio
