| diyAudio Sponsor | ||
Out of curiosity, has anyone out there tried a hybrid partial feedback SE amplifier using one of the IXYS or Supertex depletion mode fets for the front end? Both a Schade-style feedback or an E-linear scheme would be possible. I'm already doing something similar (but all sand-state) in my "SiC Puppy" SE amplifier (see the Pass Labs section if you're curious), and it sounds pretty nice. I'm definitely going to try it some time, but I have projects stacked up to the moon right now, so I won't act on this idea until I finish at least a few of the "works in process".
#2 |
In one of the sound practices issues (1994), J.C. Morrison had a design (Dinosaur) with a 2SK30 fet at the front.
#3 |
Why not use "SEARCH" before asking
Michael Koster has done it the way it should be done! This one is seriously engineered without wasting components: Most linear triode-strapped pentode
Brgds Lars |
#4 |
If you could dig up that schematic, I'd like to compare it with what I have in mind. This isn't the first tube/fet hybrid I've done. The "Shrine", my very first tube amp, married a triode- cascoded jfet with a ultralinear 1625 output stage. I have a few other sand/vacuum mutant hybrids still in the pipeline.
I haven't seen anyone marrying a naked depletion mode mosfet with a pentode in the classic "Schade" feedback scheme. I've seen jfet/tube hybids used for RIAA input stages before I ventured to do the "Shrine" amp. Given the age of the example you cite, I suspect that may be another example. |
#5 |
Check the link in the post above yours. Couldn´t be more "naked"!
Brgds Lars |
#6 |
Revintage - you always have the snarky way of expressing yourself... The Koster circuit uses a mosfet in front, but it wasn't what I had in mind at all. I'll be doing a classic 2-stage Schade feedback circuit using something like a DN2540N5 for the front end (pentode in disguise) or one of the smallish IXYS 1000V depletion mode fets with the beam power pentode of my choice for the output. I may look at cascode vs. conventional front end to see what difference it makes. I really don't care if you think that wastes components or not, after all, they're mine to waste if I see fit.
#7 |
The Koster circuit looks similar to what I've been simulating with a Zen variant I'll get around to building one of these days, except that mine's a class A push-pull (Revintage wouldn't like the component count). I may try his circuit with my "Shrine" amp (I've been musing about converting it to partial feedback for some time) to see the difference between the classic Schade scheme and his. I would still use the jfet cascoded with a triode I used in the original amp as input stage, as that's already in place. I'll try the classic Schade circuit first, as it's the least violent rearrangement of what I already have in place, and I don't have a lot of spare time. Right now the "Shrine" circuit uses a jfet cascoded with a triode at the input, driving an ultralinear-connected 1625 at the output. If I keep that lineup, I'll probably settle for the direct-to plate connection between the input stage load and the output, but keep the AC coupling between stages (it's more parts, but I'm not rebuilding the whole amp). If I want to go all the way, I'll build another amp.
Jaap - I'm still interested in seeing that 1994 circuit if you can lay hands on it. Last edited by wrenchone; 14th September 2011 at 07:04 AM. |
#8 |
No need to start personal disputes...
![]() I actually found the start of the thread very interesting. Since wrenchone asked for a hybrid with depletion Mosfet and maybe Schade-style feedback, I don't see why Micheal Koster's circuit that revintage suggested does not fit the bill (low component count or not). Could you (wrenchone) elaborate on why this is not what you had in mind? I am still on the lower slope of the learning curve, so I always appreciate comments/discussions on a particular circuit - good way to learn. There are often issues with a particular design, I just did not have on the radar. Thanks for the effort. Martin |
#9 |
I was looking for a simple classic two stage AC coupled amp, pentode input and output, partial feedback, with mosfet substituted at the input.
Koster's amp is an extreme stripped-down version of the same, omitting the AC coupling between stages and feeding completely back into the input stage from the output instead of partially. It took a second look to see that. Two of the more conventional schemes as compared to Koster's are the "Schade" partial feedback circuit (named after its inventor, the father of the beam power pentode), which has a feedback resistor connected between the plate of the input stage and the plate of the output tube, and the "E-linear" scheme, which connects the plate load resistor of the input stage to an ultralinear tap on the output transformer primary instead of to B+. The Schade scheme was what I originally had in mind when I posted. Koster's scheme moves that input plate load resistor right down to the output tube plate (the ultimate "E-linear") for even more feedback. If I had waded through an bunch of Schade posts/threads, I might have eventually found Koster's circuit, as it was buried 1/3 of the way into "the most linear triode" thread (a thread I stopped following far enough back I'd forgotten about it). The other innovation of Koster's circuit is the direct coupling between input and output stages. As usual with DC coupled circuits, it has some compromises. I don't necessarily like blowing 70V across a cathode feedback resistor. The cathode is elevated at 70V above ground as well, which is getting a bit close to the usual 100V cathode to filament voltage limit. In the usual tube amp, it's possible to elevate the filament a bit with a bias network to reduce the heather to cathode potential, so that can be worked around if you accept the cathode resistor voltage drop. The advantage of using the mosfet at the input with Koster's scheme is that it can operate quite comfortably at 30V drain voltage and still have plenty of room for signal swing. This limits the amount of extra voltage dumped on to the cathode resistor of the output stage in addition to what already needs to be there to properly bias the output tube. The mosfet looks pretty much like a pentode in overall V-I characteristics, so it lends itself well to a Schade/E-linear-style feedback scheme, partial or full-tilt. You could potentially try the same thing with a pentode front end, but with a pentode, you would need to run the plate at a much higher potential to prevent it from running out of gas, meaning that you'd have a even higher potential across the cathode bias resistor of the output stage (more voltage/power burned). It may be possible to "starve" a pentode to allow it to run at lower plate voltage, but this would most likely eat most of the gain/transconductace that makes this feedback scheme so attractive. Compromising and using AC coupling between stages would allow you to do a similar scheme, at the cost of a coupling cap and another resistor. The one big difference between the mosfet and the pentode is that the mosfet is more directly affected by Miller capacitance between gate and drain, not having the shielding effect of the pentode's screen grid. Cascoding the mosfet would help fix that, and might be worth a try - the input would be a bit easier to drive. It might also have better THD at high frequency - remains to be seen. There are elements of Koster's circuit I might end up using, DC coupled or not. A "hey, other people are trying this, look at this link", would have worked just as well as the "direct" approach. As I mentioned previously, I'll probably try an intermediate version on an amp I already have built up. I have about 8-9 amps in various stages of construction, so I want to limit involvement just now so I can finish a few things. I want to keep the input stage I already have to avoid completely tearing the amp apart. It uses a jfet/triode cascode on the input stage, which needs some voltage at the triode plate to work properly. The guts are all inside a 6" cube with tubes on top, so DC coupling and an extra 10W or more dissipation inside would not be appreciated. The amp uses a custom SMPS that also fits inside the cube - I don't want to rewind the transformer to make up for the extra voltage drop across the cathode resistor. This means, I'll try the Koster feedback scheme with AC coupling. Not as simple as some would like, but as simple as I'm going to make it for right now. |
#10 |
Thanks wrenchone, for going step by step through the mentioned circuit and the one you have in mind and mentioning the problems.
I had noticed the problem of limited voltage swing if the Mosfet would be replaced by a Pentode but did not see the problem of the 70V burned in the cathode resistor (and the cathode to filament voltage limit), which might be a problem in some cases. Thanks again for the detailed explanation. Martin |
| Question Regarding a Partial Feedback 807 SE | JPeitzman | Tubes / Valves | 7 | 28th January 2011 12:54 PM |
| Need help on 811A partial feedback | WT | Tubes / Valves | 16 | 14th July 2010 07:43 AM |
| Partial feedback confusion | Jeb-D. | Tubes / Valves | 4 | 22nd April 2008 05:20 PM |
| partial feedback stuff | dave dove | Tubes / Valves | 3 | 14th January 2006 11:02 PM |
| Partial feedback DHP SE amp | Fuling | Tubes / Valves | 21 | 5th August 2005 09:20 AM |
| Page generated in 0.13437 seconds (83.36% PHP - 16.64% MySQL) with 11 queries |
