| diyAudio Sponsor | ||
what you suggest for +B (300-400V) for a connector(jack and plug) I was looking at the Neutrik powercon but I don't think they are rated beyond 250V. I would like to house the PSU seperate from the main tube pcb. Is there any issue with running seperate DC heater as well? Is 2 feet too long for the HV power cable? Thx |
#2 |
Hi!
I use Amphenol MS series connectors. They are available with various numbers of pins. I routinely use external PSUs. No probelm to also have the DC heater supply external. I always keep the last LC stage for each voltage in the amp chassis. Even long umbilical runs are no problem this way Best regards Thomas
http://vinylsavor.blogspot.com/ |
#3 |
Do you use 2 or 3 conductor, shield?
I guess for H.V. it is better to use Teflon twister pair? Excellent advise. Thanks. |
#4 |
You can also consider an octal plug on the umbilical, plugging into
a female socket on the chassis. 8PB Cinch 5935-00-061-7250 Octal Plug-in Socket |
#5 |
Hi!
Depending on the number of voltages I have, I use 5, 7 or up to 10 pin connectors. Minimum is 5: B+ Ground 2 wires for heater safety earth I use umbilicals with a common shield around all conductors. I connect the shield on the PSU side to saftey ground. Best regards Thomas
| HV B+ switch | db! | Power Supplies | 8 | 31st October 2010 08:55 AM |
| HV Regulator | rsumperl | Tubes / Valves | 4 | 18th September 2010 07:20 AM |
| Can I use 4-pin Molex connector as speaker connector? | MikeHunt79 | Everything Else | 5 | 3rd June 2009 07:21 PM |
| HV repairman | rdf | Everything Else | 1 | 25th May 2007 04:02 AM |
| HV ON noise | morfeas | Tubes / Valves | 13 | 1st February 2004 08:37 AM |
| Page generated in 0.08864 seconds (73.00% PHP - 27.00% MySQL) with 10 queries |
