diyAudio Sponsor
Old 12th September 2011, 08:03 PM   #1
Default Quick OT Question
I've done a lot of audio work during my career, but nothing with transformers. If I remember correctly from school (assuming ideal lossless components), the voltage swing across the primary of an OT will be twice the B+/Vcc voltage when driven fully. Is this correct?
With a push-pull output, would both half cycles derive the same voltage boost? (This would certainly be a power advantage with twice the voltage swing!)
I have a little project here, replacing the #19 (dual triode) output tube on an antique radio console with a pair of high voltage power mosfets. I hate to spoil the radio's originality, but this tube's audio just stinks! Even my AA5s sound much better.
Bobby Dipole
Old 12th September 2011, 08:54 PM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
For SE, the energy stored in the inductance of the OPT primary will cause the voltage across the primary to be almost 2*B+ when the output stage is driven fully.
~Tom
quick question. timwebb Car Audio 5 29th July 2011 06:12 PM
OT question - will it work? atmars Tubes / Valves 3 28th November 2008 01:25 AM
Really OT question about paint Conrad Hoffman The Lounge 14 22nd January 2008 08:28 AM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
OT Overload question alexmoose Tubes / Valves 1 9th May 2006 12:56 AM
Page generated in 0.05936 seconds (83.59% PHP - 16.41% MySQL) with 10 queries
