diyAudio Sponsor
Old 10th September 2011, 06:04 PM   #1
Doz is offline Doz  United Kingdom
Doz's Avatar
Default Eagle PCB
Does anyone here use the Eagle PCB cad package.
I used to use a product called "EasyPC" , but it doesn't support tubes, so I've been trying Eagle , along with the "tubes.zip" library.
I have one question.
When I add , for example, an ECC83, it allows be to position both triodes, V1a and V1b , but neglects to put down the heater connections, which I can see in the library are listed. How do I get round this? Can I manually add then to the schematic or layout?
Other than this issue, it looks really promising for my designs.
Thanks in advance!
"To err is human.. to make a real balls-up requires a computer"
Old 10th September 2011, 07:01 PM   #2
dsavitsk's Avatar
After you add the tube, click STOP. Then, find the INVOKE button on the left and select it. Then click one of the tube schematic symbols -- this will open a box with the heater option shown. Click it, then click OK, then place the heater.
Eagle can take a while to get used to. Also, please note that you may need to alter the tube foot prints in the library for most common tube sockets.
Edit: Also, both Pete Millett and Tubelab have libraries available with some tubes. And, on the Cadsoft website there is a tubes2 library that may be useful.
http://www.ecpaudio.com
Old 10th September 2011, 07:24 PM   #3
Doz's Avatar
Thanks a lot. The interface does seem very similar to EasyPC, and I'm making progress.
Thanks for the help, very much appreciated.
Suggestions on PCB: LM317 As Walwart Regulator (1st Eagle PCB) tommy_o Power Supplies 10 14th July 2011 03:05 PM
Eagle PCB d3imlay Solid State 0 16th October 2008 12:01 PM
EAGLE PCB help with socket on it krusty75 Tubes / Valves 13 14th May 2008 09:11 PM
PCB Manufacturing Process with Eagle PCB Algar_emi Parts 0 21st September 2007 01:07 AM
Eagle PCB VS Express PCB jamesjung21 Parts 22 21st March 2007 03:50 PM
Page generated in 0.06046 seconds (81.54% PHP - 18.46% MySQL) with 10 queries
