| diyAudio Sponsor | ||
Looking at the voltages around the input stages, the voltage drop across the 1k resistor would suggest that a current of 3mA is flowing through the circuit. The data curves for a 250V Plate supply at 3mA would suggest that the 6N1 is not being operated at its most linear part (Red line on graph). Does the Team think that the current needs to be increased to say 10mA as shown by the Green line to improve its operating point? Perhaps I have this all figured out wrong, after all the amp does sound nice as is, and the fear of adjusting may push the operating conditions of the phase splitter into a bad area.
Does anyone have any suggestions for the improvement of these stages? I have a feeling that any answers to these questions would be looked upon with great interest by Yaqin owners. Les P.S. The maximum plate voltage of 250V for the 6N1 suggests it is being pushed a bit in the Yaqin circuit :-( I also realise I made a mistake in that the plate voltage of the first amplifying element is 121V and not 250V, but the curve is still very bent at this point. Last edited by Hi-Q; 9th September 2011 at 10:41 PM. |
#2 |
frugal-phile(tm)
IIRC Daniel & i discussed this and thot the a suitable mod would be to crank the current. Somewhere between 5 & 10 mA seems to be a concensive point.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Obviously some component values would have to change. I have tried to remodel based on increasing the current from 3mA to 10mA but something tells me things are not as simple as this. Does anyone have the ability to perhaps Spice the circuit or advise on component changes?
#4 |
with 120V plate to cathode at 10mA the Vgk would be around 0V...not good. So maybe 5mA is a better target... to achieve it I would go with a 220R for R104 and 180R for R102, 180R for R102 combined with the existing 47R would be 227R, a bit more than 220R on the top, but still more or less balanced. Or go for 170R for R102, but 220R and 180R are standard values!
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY! |
#5 |
Thanks for your input Erik, what was I thinking? R104 should be 330R in my marked up attachment. Funny how the brain gets disengaged when you are sat at the keyboard
Les |
#6 |
Yes, you are right: the 120V should be preserved for the phase splitter. Looking again at the schematic I see that the upper tube has about 180V plate - cathode, while the lower has 120V...Using similar valued cathode resistors, as I suggested before, will bring these values to 150V and 150V = no good. Therefore I think your values are better (with 330R instead of 3k3, of course)... and experimenting is never a bad idea
#7 |
The first issue with the Yaqin I'd sort out is the filament - cathode safe voltages are exceeded, with 121V and 127V on V1A and V2 respectively.
This is looking for trouble and I suspect no good for the sound. |
| Yaqin mc10L | gasman | Tubes / Valves | 167 | 21st May 2012 02:54 AM |
| Help and your input on YAQIN MC10L EL34 | kalinga | Tubes / Valves | 6 | 27th January 2011 08:39 PM |
| Yaqin MC10L and KT88 | megalodementia | Tubes / Valves | 21 | 15th January 2011 01:51 PM |
| Add rectifier tube to yaqin mc10l? What size is best? | bichela | Tubes / Valves | 4 | 12th August 2010 06:59 PM |
| need help with yaqin mc10l | marley | Tubes / Valves | 10 | 30th April 2010 01:40 PM |
| Page generated in 0.10157 seconds (76.49% PHP - 23.51% MySQL) with 11 queries |
