PP PSU:  How much ripple is too much ripple?
Old 11th September 2011, 06:59 AM   #11
artosalo is offline artosalo  Finland
artosalo's Avatar
artosalo, out of interest did you have matched output tube idle currents, or better still were you able to check output hum levels whilst you varied idle current mismatch?
There is bias adjustment for each output tube and idle currents were set identical ( about 50 mA).
I did not test the effect of current mismatch. The global negative feedback was 16 dB.
PP PSU:  How much ripple is too much ripple?Hide this!Advertise here!
PS ripple vs output impedance for PP AB1 boywonder Tubes / Valves 4 22nd September 2009 08:54 PM
Measuring PSU ripple. How do you do it? Jonathan Bright Solid State 18 21st July 2004 12:07 AM
psu problem / ripple current / esr metebalci Solid State 3 30th April 2004 10:56 AM
Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple the toasted Solid State 6 18th February 2003 03:13 PM
How low should PSU ripple voltage be in a preamp? DrewP Tubes / Valves 5 6th February 2003 08:43 PM
Copyright ©1999-2017 diyAudio
