Grounded Grid TRANSCENDENT line stage
Old 17th September 2011, 06:20 PM   #11
widi is offline widi  Spain
widi's Avatar
Hello friends.
I have a small problem with the preamp, so I have if you can solve.
I use this preamp with a solid state amp, and to be operating without any input in the preamp, and with the volume to a minimum, be heard, sssshhhh, as if the volume to maximum.
I connect any source with a moderate level is not heard.
How I can fix this noise?.
Thank you all in advance.
Old 17th September 2011, 08:55 PM   #12
rhing is offline rhing  United States
rhing's Avatar
Widi,
You might want to check your ground connections and solder joints, especially with ground connections on the RCA input jacks. Make sure the RCA ground connections are insulated from the chassis. Others here may have better advice.
As for the Grounded Grid, I have a friend who had a Grounded Grid with a Goldpoint stepped attenuator with Dale resistors and an Aikido with an Alps Blue Velvet volume pot. The Aikido sounded much better. Swapping the volume pot and stepped attenuator just made the difference even more noticeable. Interestingly enough, my same friend kept the Aikido and sold the Grounded Grid, and he's running the Aikido with a Transcendent Sound T-16 OTL power amp with his Quad ESL-57's, and getting excellent results.
Rich
Old 12th September 2012, 08:41 PM   #13
montesquieu61 is offline montesquieu61  United Kingdom
Sorry to resurrect this thread, but has anyone cracked the problem of too much gain in this preamp? I'm getting recommendations to stick a pair of resistors at the pot, but I'd rather do something with the main part of the circuit.
Grounded Grid TRANSCENDENT line stageHide this!Advertise here!
Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... Mark A. Gulbrandsen Tubes / Valves 801 1st September 2015 04:06 PM
FS transcendent sound grounded grid preamp Jed Swap Meet 2 26th August 2007 03:12 AM
