diyAudio Sponsor
Old 9th September 2011, 08:48 AM   #1
Skorpio is offline Skorpio  Denmark
Default Speaker impedance and amp matching?
My speakers have a 7.5 Ohm minimum in the range 100-300Hz and below 100Hz it raises to a 17.5 Ohm top at 50Hz.
This is fairly flat and my Simple SE has an output impedance of aprox. 2 Ohm. This gives a amplitude difference of +1.1dB at 50Hz compared to 100-300Hz level.
But listening, this difference seems larger. I would have expected a 2-3dB difference, before measuring...
Could the resonance at 50Hz give a dynamic sound "larger" than static measurements shows?
If so, could a R-C-L correction network fix that?
Values at 12R+1000uF+10mH could be used for test...
Old 9th September 2011, 02:24 PM   #2
DF96 is offline DF96  England
Yes, that is what a resonance does. It, in effect, amplifies the input. A lower output impedance (=higher damping factor) would help damp the resonance a little - that is why most amps have a low output impedance. The idea is that you can use electrical damping on a mechanical resonance. SE is an exception because they usually don't have much NFB so high output impedance. SE may be best with speakers designed for them, which have mechanical damping of the bass resonance instead. Such speakers might be overdamped with a conventional amplifier.
Old 10th September 2011, 06:22 AM   #3
Hello,
maybe you also can fix a little bit more damping-material into the box, this is the acoustic method. When it´s a BR System put something into the BR-Tubes. Most BR Boxes are "tuned" between 50-30Hz.
Whatever, you´ve to use the "try an error" Method. Nobody can really say what is to do.
musical regards ULi
Amplifier-speaker matching impedance djrama Solid State 13 3rd October 2010 07:29 PM
Help with matching speaker impedance to old tube amp idebb Tubes / Valves 8 11th April 2010 04:18 AM
question about coupling & impedance matching tabooes Parts 3 13th July 2006 05:07 PM
impedance matching to a pro amp... MyNameIsJake Solid State 2 4th June 2006 05:32 PM
Impedance Matching & Crossover network query Redhatter Multi-Way 0 6th January 2004 07:59 AM
Page generated in 0.06967 seconds (72.44% PHP - 27.56% MySQL) with 10 queries
