How to get started
Hi all,
So many helped me me understand what I have in terms of parts to work from and what to do with them. That said now it's time for me to start getting to work on my guitar amp, but I am still very lost. last night I wiped the box down with IPA to clean it. but didn't want to touch any electronics because I didn't know where to start. I will be using a Davis Model 106 Amplifier and frankly don't know where to begin. a few questions I have: 1) Someone mentioned turning this into a marshal 18W amp. and that all I would need is a marshal pre amp. Can someone provide a link to a schematic? I think this is what I am looking to do and the more direction I can get the better. It seems like a fairly common conversion, but I have still not found a comprehensive walk though or complete schematic that I can understand. 2) I also understand that I need to replace a lot of components, what types of components need to go, do people take everything apart? 3) How should I test things (assume all I have is a multi meter), and what should I be testing? 4) Also since I will be doing a lot of soldering I need to buy a better soldering iron. I have a budget of about $100 and am looking for a suggestion of a good soldering iron for this kind of work. Do I need a vacuum function? 5) In order to make this look the way I am hoping it will I need to unsolder everything, but that seems like a disaster waiting to happen. It seems like the sockets for the tubes are riveted in place, how do people handle that? If people would like any specific pictures of what I have just let me know where to photograph and I will. The same goes for components and other information. There is no schematic on, under or inside this amp unfortunately. Also mods I apologize if this should go in the instrument amp section, but since many of these questions are about tube amps and general steps I figures I would start here. Thanks |
Could this be the schematic you are looking for? http://www.geckoamps.com/gecko001/davis106.gif
(Google is your friend) Soldering Iron: I am a big Weller fan (google WES51 or WESD51), but you can probably find something comparable at a lower price. I would definitely buy one that allows you to regulate temperature. Even though you may not need that for this project, it's going to be a good feature to have for more delicate soldering "around the house". Vacuum? Maybe, but a cheap desoldering gun from Radio Shack will do just fine for PCB unsoldering. If you do point-to-point, it's less relevant, IMHO. I'll leave some questions for others to answer. :D |
Or leave the sockets in place and just rewire them as needed.
I've done it both ways- replacing some parts, unsoldering parts from sockets, etc - and also just taking most of the amp out of the chassis (usually the rectifier tube socket can stay). The second way-new sockets and components- is the way i do it now- faster and less hassle. 5) Sometimes drilling rivets can work, though often they just spin under the drill. At that point a sharp cold chisel can come into play. I usually use an angle grinder and just grind off the rivet heads from the top side. A straight punch of the correct size can then drive out the rivet. As you imply, unsoldering components from old tube sockets can end with breaking off a lug (usually the last one). It is good practice, though.:D |
If you press hard then the drill will bite and spin the rivet and might damage the pcb. |
You can always 'set' the rivet if it starts spinning, with a center punch or cold chisel corner into the edge. By 'pcb', do you mean phenolic wafer tube socket material? Most of those sockets that I've seen are so 'crispy' that I just junk them and put in a new socket. YMMV. In the past, I've spent 15min cleaning up an old socket. A new one is a few dollars, so I don't do that very much any more! |
Carter you surely mean a 18watt Marshall, right?
So EL84 PP? |
I suppose my assumption was that there would be some step by step documentation of how to do this, but it seems I am coming up short. I don't think I have the knowledge (this is my first build), to figure this out on my own. Here is the best info I have gotten thus far: Gecko #1 - 18 Watt Lite III I emailed the person who did this modification and he said he would try to send me more details. I was hoping to keep the chassis and box of the davis, so this seems like it might be a little more tinkering than I was hoping. I guess I feel that I could easily swap some old components for new ones and then change some wiring or add a new circuit, but I don't have the details on what needs to be done and lack the knowledge and understanding to figure it out myself. All of you help is very appreciated. |
| All times are GMT. The time now is 03:51 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
