Old 30th August 2003, 03:49 PM   #1
GAK is offline GAK
Unhappy 6d22s
I'm searching a data sheet for the rectifier 6D22S.
Svetlana's site doesn't work for the moment but I'm working for my preamp!
let's boom chitty boom
Old 30th August 2003, 04:35 PM   #2
Tom Bavis's Avatar
The main Svetlana entry page is gone, but all the other pages are stilll there
http://www.svetlana.com/docs/tubeframe.html
Old 31st August 2003, 10:36 AM   #3
diyAudio Senior Member
fdegrove's Avatar
An article by Eric Barbour on the 6D22S;
SVETLANA 6D22S
Frank
Old 31st August 2003, 11:44 AM   #4
Pjotr's Avatar
Does someone know what happened to Svetlana in the States? I found the following note on http://store.yahoo.com/triodeel/index.html
Note about "SED" Tubes: These used to be called Svetlana before a legal dispute forced the factory to quit marketing under the Svetlana name in the USA.SED's are the same tube, same box, same "C" logo, made in the same factory in St Petersburg, Russia as before. Note that there are tubes not made in the St Petersburg factory that are sold, legally, in the USA as Svetlana tubes.
Cheers
Old 31st August 2003, 02:11 PM   #5
GAK is offline GAK
Old 1st September 2003, 03:59 PM   #6
fdegrove's Avatar
Comrade Pjotr,
Svetlana made tubes are now available as Winged C amongst other names, I presume.
The distribution is being negociated by P.M. Components ( you know, the Golden Dragon junk triad).
I heard rumours of Svetlana being in financial trouble, the Svetlana brandname issue in the U.S. seems rather unlikely as an explanation.
Here's some more info: go to the "Tubes" menu and click "Winged C".
AES
Frank
Old 1st September 2003, 07:22 PM   #7
Pjotr's Avatar
Thanks Frank for the explanation.
Btw HERE the direct link to the page you mentioned.
Cheers
Old 2nd September 2003, 12:55 AM   #8
Brett's Avatar
GAK, there are a lot of alternatives to the 6D22S too, such as the EY500A and others like the 6CJ3 which don't need a top cap. The 6D22S is nothing special in it's class, except for being the only one still manufactured, but there is a ton of NOS dampers out there available cheap.
Old 2nd September 2003, 09:36 AM   #9
GAK is offline GAK
Brett
Thanks for the alternatives.I'm planning to use the 6D22S for a full wave rectifier(2 of them) for my ECC82 SRPP preamp.I need something good giving plenty mamps.
I'll use 3 p-filter(30uF MKP-10H-200uF MKP split to 7H-200uF to the R channel and 7H-200uF MKP to the L channel)
I haven't decided which rectifier to use ,yet.So any suggestion is acceptable.
Old 2nd September 2003, 09:46 AM   #10
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Without topcap:
6AX4 are plentyfull as well.
With topcap.
I have been using EY81...but have been running them for 3 months now without a cage...which is pretty stupid..since kids or adults for that matter can be fried if they touch the metal parts that are still exposed!
Bas
6S33S & 6D22S for sale Vladi59 Swap Meet 0 22nd December 2008 03:04 PM
6D22S Getter Question Ardee Tubes / Valves 5 27th September 2006 09:35 AM
How to use Svetlana 6d22s? protos Tubes / Valves 3 3rd February 2006 03:51 AM
6d22s adalin Tubes / Valves 4 26th September 2004 02:26 PM
6D22S Damper Tubes Peter Menting Tubes / Valves 15 27th March 2004 02:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
