diyAudio Sponsor
Old 5th September 2011, 06:11 PM   #1
davorin is offline davorin  Croatia
Default EL12N in JCM800 clone
Just finished clone of MARSHALL JCM800 (model 2204 with small modification) with 2xEL12N in output. Guitar sound is bether than any amp that I build before (more than 400 amps for guitar!)! First I tray with 12AX7 on first position (normal, ECC83 Philips/1977Year/NOS) with perfect sound, but have too much gain, and than try 12AY7 (Electro-Harmonics; new production) with less gain. EL12N are NOS tubes from Germany (DDR; RFT production; NOS from 1959 year!).
Old 16th September 2011, 01:34 PM   #2
Yesterday I put amp in box with speaker (Celestion G12Vintage-60W/8 Ohms). Output power is >40W in normal pentod-mode and ~12W in triode-mode (screen to plate via 470 Ohms/2W).
Old 16th September 2011, 05:35 PM   #3
HollowState's Avatar
VERY nice job!
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 16th September 2011, 08:54 PM   #4
Thanks!
Old 18th September 2011, 04:42 PM   #5
Funker is offline Funker  Germany
Hi Davorin,
nice work. Respect! In Germany we would say: Geiles Gerät!
I own loads of these nice output valves. I also made a lot of guitar amps, but I never tried these valves. I should try them the next turn.
regards
Old 18th September 2011, 05:38 PM   #6
Thanks! First amp with EL12(Telefunken) for guitar, I buid ~1974-'75 (SE-ClassA-8W output). I remember perfect sound of guitar from that amp. Many year I can't bay EL12 (or EL12N and EL12SPEC) anywere, but few monts ago I bay 14 tubes EL12N (from USA, hi!) and decided to build bigger and stronger amp.
Old 24th October 2011, 01:24 PM   #7
I receive few asks for shematic. Here are (sory for hand drowing):
Old 24th October 2011, 03:33 PM   #8
Hi Davorin,
thanks a lot for the drawings!
regards
Wolfgang
DF6ZC
New Project (The best JCM800 SS emulation)? mensur Instruments and Amps 3 11th March 2008 10:41 AM
JCM800 Mod iggy80fr Instruments and Amps 1 6th September 2006 09:47 PM
clone AN/K ccopp Multi-Way 0 9th July 2006 08:24 AM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
JCM800 as a poweramp, the signal level mdream Tubes / Valves 4 9th December 2002 01:45 PM
Page generated in 0.09235 seconds (74.07% PHP - 25.93% MySQL) with 11 queries
