diyAudio Sponsor
Old 3rd September 2011, 09:14 PM   #1
jtsaudio's Avatar
Default Solid-state replacements for PAS2/3 rectifiers?
The PAS2/3 uses a 12X4 rectifier, and a selenium rectifier.
I am rebuilding a PAS where the Selenium rectifier has gone bad, and the 12x4 is missing.
I have heard of DIYers rebuilding with all solid-state rectification.
Any recommendations?
Old 3rd September 2011, 10:35 PM   #2
ArtG is offline ArtG  United States
If you are going to keep the stock filter network, you can safely replace the tube rectifier with a pair of 1N4007 diodes, or preferably UF4007 diodes. It will raise the B+ voltage a few volts, but, unless the "can" capacitor is in poor condition because of age, there should be no problems. It will have the beneficial effect of reducing the load on the transformer heater winding. If you are concerned about the filter capacitor, it's easy to install a CL200 "inrush limiter" in series with the power transformer primary.
Old 4th September 2011, 04:16 PM   #3
jtsaudio's Avatar
I was thinking of replacing the stock filter network(esp. capacitors), due to the age (40-50 yrs) of the components. Any suggestions for a better replacement for low noise? (Any schematics?)
Old 4th September 2011, 07:52 PM   #4
kstagger's Avatar
Triode Electronics / SDS has a neat little drop-in board that sits on top of the original filament capacitors. It replaces the can cap, filament supply and even has a provision for solid-state rectifications. However, 12X4s are dirt cheap and last forever in the PAS.
Old 4th September 2011, 08:18 PM   #5
How extensively do you wish to revise the preamp? Are you thinking of just the power supply, or do you wish to upgrade other boards and components for better performance? There are many upgrade choices for this preamp. In the last week, I've just completed one that I find to be, very, very good.
Old 6th September 2011, 04:19 AM   #6
jtsaudio's Avatar
Default Just a line amp (from scratch)
I have an enclosure, but the boards and most other components are badly oxidized, due to exposure to the elements(the PAS was given to me).
I was thinking of new line amp boards (any recommendations?), and a new power supply board (like Sheldon Stokes' board, which permits elimination of the selenium & tube rectifiers). Plus an upgraded volume pot.
Basically all I will reuse is the(cleaned)chassis and power transformer to build a tubed line control amplifier, which I will use to drive, alternately, an ST70 and a PS Audio power amp. My first foray into tubed preamps!
-Joe
p.s. Did I mention I'm on a tight budget?
Old 7th September 2011, 12:28 AM   #7
There are many good boards and power supplies available for this preamp. If you are on a tight budget, though, it’s possible to save some money if you feel confident stuffing the boards and doing some of the fabricating yourself. The picture, attached. is an example of this. I fabricated the power supply board myself, using a piece of FR4, a few turrets and a few “standoffs”, and other normal PS items. The large capacitors, 330mfd/400VDC, are surplus from “All Electronics” at a cost of $2.50 ea.
The phono board is original, with some components changed. The line stage is a "Norman Koren” designed board, sold by “Classic Valve Design”, that I stuffed, and added a custom built tone control board, just visible in the lower part of the picture.
As I stated, I’m very, very, pleased with the sonic results of this particular pre-amp so far.
I have additional changes planned for this unit in the future, including replacing the current PS with an active regulator, replacing the volume control with a stepped attenuator, and a few other changes.
I’d recommend that anyone looking to rebuild/modify A PAS preamp should spend some time studying Koren’s website. I’ve included a link below to part 1, follow it to part 2:
Spice and the art of preamplifier design, Part 1
Old 7th September 2011, 02:14 AM   #8
Art -- Nice to see more of your superb work -- as usual!
Dave
Old 8th September 2011, 02:02 AM   #9
Thanks!
Of course, I’m not trying to “show off” my work, here. There are many folks that produce much more “polished” looking results than I do. I’m again trying to illustrate the point that with a well designed circuit as starting point, a little thought, some planning, and patience, will achieve excellent results without spending “big bucks”. A preamp is a component where individual sections and parts (line stage, power supply, volume control, etc.) can be improved incrementally, as money and time allows.
Best replacement solid state rectifiers for a 400V 125 mA supply in a tube amp needsp Tubes / Valves 1 15th July 2011 01:32 PM
Rectifiers: Tube vs Solid state.. cathode_leak Tubes / Valves 26 13th May 2005 12:45 AM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
Page generated in 0.10286 seconds (85.22% PHP - 14.78% MySQL) with 11 queries
