diyAudio Sponsor
Old 3rd September 2011, 12:41 PM   #1
Default first integrated amp
hi everyone
I'm new here
my name is Dimitri, and I'd like to build a simple, little and possibly "cheap" tube integrated amp.
I have experience with electronics, but not on HIFI, I use to build guitar effects and amps. At home I have several amps like Audio Tekne, Audio Note, Quad 2, and some other, but I want to build a small one for my self (since those are used mostly by my father). I don't need much power and since I'd like to keep the enclosure small (and the costs too), I prefer a integrated one so that I can use just 1 power trasformer and 1 psu circuit. I don't need phono input, just a line input
any suggestions about what circuit to go?
thanks and sorry for my bad english
Dimitri
Old 3rd September 2011, 02:11 PM   #2
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Here are a couple of links to look at. Look for the "el cheapo." It's supposed to be a decent and affordable amp. Another option is to look for older console tube stereos that are being thrown away or sold cheaply. I found an old Packard Bell for $25 (US), pulled the amp, and rebuilt it. It turned out to be a decent little amp.
Mike
DIY Vacuum Tube (Valve) Amplifier Projects - Hi-Fi Audio
Tube & Information Page
Marantz PM8003 amp, Squeezebox Touch, DIY Krystals
Old 3rd September 2011, 03:56 PM   #3
Google for RH84 by Alex kitic. Sounds great with Russian el84/6p14p and any NOS 12AT7. And it's low cost.
Old 20th September 2011, 01:02 PM   #4
thanks guys
RH84 looks quite easy for me. can I plug the line out from pc directly to RH84 input? is the ECC81 the actual preamp stage?
JBL SA600 & SA660 integrated 2 ch amps basenjifan Analogue Source 6 2nd January 2012 04:52 PM
Resistor setup for integrated amp & headphones? Eclair Tubes / Valves 1 21st November 2008 12:28 AM
changing an integrated tube amp to a power amp f1802llk Tubes / Valves 8 10th October 2008 05:25 PM
Seperate power supply for pre-amp section in integrated amp? KevinLee Solid State 8 2nd February 2008 10:20 PM
Page generated in 0.08775 seconds (79.11% PHP - 20.89% MySQL) with 10 queries
