tube rectifier and tda 1543
Old 29th August 2003, 04:52 PM   #1
Raj1 is offline Raj1  United Kingdom
Default tube rectifier and tda 1543
I have a few tda 1543's, and I am interested in using a tube rectifier if at all possible, to run the dac chip which only uses a 5v supply, I'm not sure if tube rectifiers are available to operate at this level.
Does anyone know if this is possible and how?
Raja
Old 30th August 2003, 10:28 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
What's the motive for picking a tube rectifier?
Anything's possible but I think you may be best of with the appropriate Schottky rectifiers.
Frank
Old 30th August 2003, 10:57 PM   #3
316a is offline 316a  England
316a's Avatar
Default Beast Rectifiers
There are some rectifiers out there that could probably provide the current (dampers such as PY500a) but you'll still have to use a voltage regulator . Unlikely that any single rectifiers could provide enough current for the entire DAC . Franks's right , schottkeys are the way to go , just open up a Farnell catalogue and the choice is huge .
As an aside I have actually dabbled with valve rectifiers providing low voltage supplies and it was not easy (or small!) to implement . The design lit up the filaments of a pair of 11LE3 battery valves and used PY801's for rectification running choke-loaded from a 48-0-48v supply and DN2540 depletion msofets as current sources . This power supply scheme actually dwarfed the line stage it was designed to power and quite frankly I never got round to finishing it : far too impractical ! If anyone has managed this with a 2A3 I'd like to know !
316a
Old 30th August 2003, 11:20 PM   #4
Aud_Mot is offline Aud_Mot
If you are looking to do something different for a power supply.....
Try a conventional diode bridge with a choke (inductor) input for filtering, what some people identify as an L-C-L-C filter.
If you want to go the next step, try a shunt regulater, fed by a constant current source.
Alan Wright's interesting "Tube Preamp Cookbook" gives some interesting comments.
http://www.vacuumstate.com/
Just a thought,
Aud_Mot
Old 31st August 2003, 07:50 AM   #5
Default tube rec's
for the replies,
Yes I would like to do something different, just wondered what sort of sound I would get if this was possible,
http://www.zandenaudio.com/products/english/index.html
similar to this, but thats tda 1541,
would like less of a solid state sound from my cd's.
Raja
Old 31st August 2003, 08:16 AM   #6
Pjotr is offline Pjotr
Pjotr's Avatar
Default Re: tube rec's
If that is goal then hook-up a single triode amplifying stage behind your DAC. Bias it to some non-linear region, et voila you get all the harmonics tubes are (partly) famous for. For sure you get a much less solid state sound.
But to me this appears to be the same as using an air refresher on the toilet
Cheers
Old 31st August 2003, 08:18 AM   #7
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
As schottkys don't come close to vacuum rectifiers i've also been tempted to use vacuum rectification with a SS circuit. It should be possible to use almost any rectifier provided you're prepared to drop a lot of volts across the regulator.
Btw it's not obvious from the link to Zanden that they actually use vacuum power for the DAC. It may just be for the output valve.
Any idea what the freaky air-cored coils are for?
Old 31st August 2003, 08:28 AM   #8
Pjotr's Avatar
Hmm,
I only see a load of potcores. I appears to me that it is a passive anti-alias filter. Can't imagine that it is a PSU smoothing filter.
Cheers
Old 31st August 2003, 09:19 AM   #9
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
It appears to me that it is a passive anti-alias filter
The coils are for their patented notch filters ( output stage ).
It's only audio. Member of the non modular PCB design committee
Old 31st August 2003, 06:00 PM   #10
fdegrove's Avatar
This can be and has been done before.
You don't even need to drop all that much voltage, a choke input filter would help here already.
Frank
tube rectifier and tda 1543Hide this!Advertise here!
tube rectifier dung0981 Tubes / Valves 6 25th January 2009 12:19 PM
Z2b tube rectifier bee696 Tubes / Valves 3 4th November 2006 02:45 PM
6.3V Rectifier Tube Lit by 5V snoopyma Tubes / Valves 8 10th August 2005 06:15 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Tube rectifier for VDIGC tube psu ebijma Chip Amps 2 11th March 2004 04:02 PM
