diyAudio Sponsor
Old 31st August 2011, 07:51 AM   #1
dhole is offline dhole  United Kingdom
dhole's Avatar
Default unknown Rogers Pre Power
Hi There
Anyone help me identify these amps ?
Any help much appreciated.
Dave
The luminous space in the Sword of Orion...
Old 31st August 2011, 08:18 AM   #2
Are they ECL83's?
Old 31st August 2011, 08:25 AM   #3
dhole's Avatar
oh yes sorry two ecl 83 in the power and ecc83 and ef86 in the pre. Do you recognise the amp ?
Old 31st August 2011, 11:44 AM   #4
Fairly typical of Rogers amps of the period. They did some similar amps with EL84 and ECL86's, but not seen many with ECL83. Grey cells ageing so can't quite recall what they were called. likely to sound very nice but power limited to around 5 Watts.
Old 31st August 2011, 03:09 PM   #5
dhole's Avatar
Thanks for the info. I have struggled to find a good source of information on Rogers amps in general . Lots of nuggets here and there.
I think that it is part of the Minor Series so perhaps a cut-down cadet mk1 or Junior. I'm sure its just time till an afficianado reveals all.
D
Old 31st August 2011, 08:00 PM   #6
Shoog's Avatar
The preamps tend to be over complex and drag the performance down.
Shoog
Old 31st August 2011, 08:15 PM   #7
dhole's Avatar
unknown and overcomplex ... dang
Old 31st August 2011, 08:18 PM   #8
Shoog's Avatar
You would have to do a circuit trace to establish that it was over complex. Often it is simply cured by bypassing the pentode preamp which gives to much gain for modern situations anyway.
Shoog
Old 31st August 2011, 10:08 PM   #9
I don't think Dhole is looking for a critique of the possible defects of the preamp but wants to know the model designations of the two pieces in the Rogers 1950s range.
The preamp looks exactly like the one I bought with a couple of the Rogers Junior (EL84 push-pull) amps and is basically a version of the Mullard pre-amp for their 5-10 amplifier with a Baxandall tone control circuit. In fact I built a separate power supply for the pre-amp and gave to a guitar-playing friend as a tone control.
But I've never seen the amp before. All I can suggest is a trawl through the online Gramophone archive where you may find a review of it.
Old 31st August 2011, 10:44 PM   #10
Just had a look at Gramophone but there's nothing there. On the other hand Googling "Rogers ECL83" brings up some more photos of your amplifier and one website calls it a Rogers RD Cadet Minor but I don't know if that's true.
Suggestions needed for improving Rogers Cadet II PP power amplifier Sanjiv Sahgal Tubes / Valves 10 23rd May 2012 09:26 AM
unknown power supply good enough? nightanole Chip Amps 15 17th September 2010 09:33 PM
Rogers Cadet III Power problem ? stephen_chrol Tubes / Valves 33 7th January 2007 10:04 PM
Evaluating Unknown Power Transformers wrenchone Tubes / Valves 10 14th July 2006 04:04 PM
Unknown Power Amp JhonDoe Parts 10 30th January 2004 06:15 AM
Page generated in 0.10699 seconds (76.65% PHP - 23.35% MySQL) with 11 queries
