Tube Rectifier with transformer without Center tap - Page 4 - diyAudio
Old 19th May 2013, 08:00 PM   #31
Originally Posted by Eli Duttman View Post
Blackface,
You are headed for trouble. The forward drop in vacuum rectifiers is much greater than that exhibited by SS diodes. The B+ rail will be "short". That problem can be overcome by installing a boost transformer. Do you have the room for a boost trafo? Do you have the skill needed to safely make the modification?
Yes, I do have skill for safely mod. I don't think that there is enough room for a bit bigger PT.
If I decide to change the PT than I have to measure the B+1, B+2 and B+3. So, I have to drop all component and diagramm I have now in my old amp.
Using the smallest amount of capacitance consistent with keeping the rail voltage up definitely makes sense, when FWCT and FW bridge rectifiers are employed. No only is stress on the rectifier(s) kept down, power trafo heating, due to I2R losses, is kept down too.
Large caps. do make sense, in voltage multiplier PSUs. "Typical" multipliers are assemblies of 1/2 wave rectification units and lots of capacitance is needed to suppress ripple and provide decent regulation. The popular "full wave" doubler is, in fact, a back to back pair of 1/2 wave setups.
any information? How to calculate the PS of tube amp? Site or some simply , i.e. Excel tool?
Old 19th May 2013, 08:08 PM   #32
Soonerorlater's Avatar
Download
This is good
When white moths were on the wing,
moth-like stars were flickering out,
Rectifier options for stereo Daniels LM3875 with huge center tap transformer altie Chip Amps 4 25th May 2010 11:03 AM
dual center tap rectifier replacement dodgerblue Solid State 6 31st July 2006 05:26 PM
Transformer center tap connections Carlp Tubes / Valves 2 19th June 2006 10:01 PM
transformer with no center tap traw Parts 0 3rd June 2006 02:36 AM
Transformer Center Tap dswiston Parts 2 4th February 2004 03:09 PM
Copyright 1999-2017 diyAudio
