Tube Rectifier with transformer without Center tap
Old 16th November 2012, 12:43 AM   #21
radiotron is online now radiotron  New Zealand
Yes, it is a 6AX5GT - arranged with a plate either side of cathode for full length of cathode
Old 16th November 2012, 01:31 AM   #22
scott17 is offline scott17
That's what I thought. Thanks for the verification. I'm sure TheGimp will be happy to know.
Scott
Old 16th November 2012, 02:15 AM   #23
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Yup, that is it.
Thanks a lot.
I read through Frank's data but missed it some how.
Nice little tube.
Old 19th May 2013, 02:56 PM   #24
Blackface007 is offline Blackface007  Germany
I'm currently thinking to modify my old tube guitar amp (Guyatone GA-330-D). It has a (silicon) diode rectifier. I want to change, using tube rectifier 6X4.
The Transformator has no center tap. As mentioned by Algar_emmi I can use two diodes and R1. Atached the schematic I would like to use.
Which R1 should I use? 1M 2 Watt?
Old 19th May 2013, 04:50 PM   #25
Default Mod. old Guitar amp
I'm currently thinking to modify my old tube gutar amp from Guyatone (GA-330-D). It has a (silicon) diode (may be 1N4007).
I wanto change it to tube rectifier using 6X4 (EZ 80) but has no center tap, only 0-280. Can I put two 1N4007 and a R1 to make a center tap? Should I take R1= 1M 2 watt? Is it safe and produce a "typical tube rectifier sound"? Attached the schematic I planed to use.
Currently, If I play using overdrive pedal after about 10 minutes the make a dub....dub.. for a millisecond. It disturbes me somehow and the chassis getting hot. I heard that it could be from the old elko in tht power section (Multisection Elko:40, 20, 20, 20). Is it right?
Old 19th May 2013, 05:11 PM   #26
flatheadmurre is offline flatheadmurre  Sweden
I dont now how much current youll draw through the tube but 40uF is max and if you stay below 70mA itll work.
Measure the resistance of the PTs HV winding and add resistors in series to get high enough series resistance.
Put the resistors right in on the rectifier tube one in each anode.
Old 19th May 2013, 05:43 PM   #27
In deed 60 mA
It sounds a bit different than the schematic I have attached before. Could you please to give me the schematic?
Old 19th May 2013, 06:49 PM   #28
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
I wish people would remember - no matter whether using tube or sand rectification, it is better practice to have relatively small "first reservoirs". Though not much specified these days, even 10F to 22F are great high-voltage values. They're just so much easiier on the rectifiers, no matter what they are. In these "3 stage" filtering schemes, it makes more sense to double up on the downwind caps. And, to prefer inductors with snubber bypass resistors over just a string of resistors. More voltage delivered at every current requirement. Sweet.
But people keep thinking to use large caps up front.
I think this is because the "mathematics of power supplies" are pretty much lost to what most experimenters want to think about and work with. Its not like its any harder than the math used on the voltage and power amplification sections! But... I think it is that powersupplies are viewed as "sundry, necessary evils", and as such more or less cookbook derived. From cookbooks that aren't authorative, but just copies, of copies, of copies ... of wrong / overkill / wishful thinking / etc.
Sigh... one of those days.
GoatGuy
Old 19th May 2013, 07:31 PM   #29
GoatGuy
about the caps, it is the original schematic from Guyatone. The amp is until now sounds fantastic.
I've tried an old Teisco 10 and souns prety sweet. The only diferrent with Guya G-330-D ist the tube retifier. It is the reason why, I'm thinking to modify but to be honest with you I'm a beginner with some experiences of building tube amps from KIT such as Vibro Champ. Yes, I built it from a kind of cookbooks. Now a bit different, mod. amps from no CT trans with silicon diode to tube rectifier. I want to make sure that I make a right mod. without breaking my old amp.
Old 19th May 2013, 07:33 PM   #30
Eli Duttman is online now Eli Duttman  United States
Blackface,
You are headed for trouble. The forward drop in vacuum rectifiers is much greater than that exhibited by SS diodes. The B+ rail will be "short". That problem can be overcome by installing a boost transformer. Do you have the room for a boost trafo? Do you have the skill needed to safely make the modification?
Using the smallest amount of capacitance consistent with keeping the rail voltage up definitely makes sense, when FWCT and FW bridge rectifiers are employed. No only is stress on the rectifier(s) kept down, power trafo heating, due to I2R losses, is kept down too.
Large caps. do make sense, in voltage multiplier PSUs. "Typical" multipliers are assemblies of 1/2 wave rectification units and lots of capacitance is needed to suppress ripple and provide decent regulation. The popular "full wave" doubler is, in fact, a back to back pair of 1/2 wave setups.
Eli D.
Tube Rectifier with transformer without Center tapHide this!Advertise here!
Rectifier options for stereo Daniels LM3875 with huge center tap transformer altie Chip Amps 4 25th May 2010 11:03 AM
dual center tap rectifier replacement dodgerblue Solid State 6 31st July 2006 05:26 PM
Transformer center tap connections Carlp Tubes / Valves 2 19th June 2006 10:01 PM
transformer with no center tap traw Parts 0 3rd June 2006 02:36 AM
Transformer Center Tap dswiston Parts 2 4th February 2004 03:09 PM
