| diyAudio Sponsor | ||
Hello,
I am planning to build an OTL Circlotron. This is the input driver stage. Well, really this stage can be used in a push pull Amp. I would like to listen your comments and suggestions to improve this design. Thanks |
#2 |
Personally--And, its just my opinion....
Too complicated, too much sand for no obvious advantages... A straightforward gain-stage, maybe MOSFET loaded, then concertina phase-splitter done well is hard to beat.... --Simple, easy and a good performer. Why complicate the wheel!
Das Beste Oder Nichts |
#3 |
Here You can found some answers and some schematics related to OTL Circlotron power Amp topology : What tubes for a tube amp?
Best Regards |
| 6c33 otl amblifier | takiskatsikas | Tubes / Valves | 20 | 26th August 2010 10:35 PM |
| Designing an OTL / Circlotron | Dr Croubie | Tubes / Valves | 32 | 4th July 2010 06:48 PM |
| 6S19 Circlotron (OTL) | Fuling | Tubes / Valves | 62 | 13th November 2008 11:16 AM |
| schematics for 6C33 single ended OTL? | vincent_brient | Tubes / Valves | 7 | 7th July 2006 07:03 PM |
| 6C33 Circlotron | pat49hk | Tubes / Valves | 50 | 26th January 2006 09:06 AM |
| Page generated in 0.08368 seconds (68.39% PHP - 31.61% MySQL) with 11 queries |
