diyAudio Sponsor
Old 28th August 2011, 10:58 AM   #1
Default the tv underrated tubes
i just stumbled across some tv damper diodes and cant stop thinking these must be pretty damm underrated .
take for example the py500 its extremely rugged . cheap . and can withstand a punishment from hell cathode is rated for something like 1A peak the cathode surface is bigger than any power tube ive stumbled across . its also readily avalable dont be fooled by 15 ebay hits . every one whit a stack of tubes will have them . once there is a demand more will pop up
i think two of these half wave rectifiers should be good upto 300-400ma .
when air cooled
what im not getting is why is nobody using them in 211 /845 amps ?
same story goes for some sweep tubes 519 is rated for 35w then you have your amateur radio operators using them at 100w per bottle . whitout any problems cathodes are HUGE . edit most of these are even available whit 6v filaments
Old 28th August 2011, 05:05 PM   #2
работник
Rod Coleman's Avatar
TV Efficiency (Damper) diodes really are good for power amps. They are my first choice, especially for the slow 30s warm up. Use them hybrid-bridge style with 2x UF4007 and a snubber RC network, and you can use a simple secondary transformer - the performance is unbeatable. I bought a box of PY500As a while ago, to keep stocked up.
Lundahl Transformers - Hybrid power supply
The PL519 is no secret though, and I think the good ones (Mullard of course) are near to exhaustion. Tim de Paravicini (E.A.R.) probably bought them all. I haven't tried the Russian 6C4x yet, but I am sure they will be excellent value.
With the P-series valves [300mA series heaters], the only precaution to be aware of is that these have heaters designed for series operation, and will draw a very large turn-ON current pulse if you run them directly across a transformer secondary (eg 42V for a PY500A). To do it right, allow 15-20% excessive voltage, and add a series resistor to soak it up. Or, Run them dc with a CCS to control the current.
Old 28th August 2011, 05:28 PM   #3
Another great damper is the 6AU4. For less demanding situations, the 6BY5 is 2 distinct damper diodes in a single bottle.
With its little cathode cap, the Russian 6Д22С (6d22s) merits consideration. A MAGNOVAL socket is needed.
Eli D.
Old 28th August 2011, 06:05 PM   #4
Yvesm is offline Yvesm  France
Yvesm's Avatar
Originally Posted by Rod Coleman View Post
. . . Or, Run them dc with a CCS to control the current.
And you'll obtain a looooonger warm up time
Old 28th August 2011, 08:18 PM   #5
... I bought a box of PY500As a while ago, to keep stocked up.
PY500 is really suitable rectifier for audio use, I've tested them few year ago and I bought 20 pieces for future project with GM70 ...
tubes.rs
facebook.com/tubes.rs
Old 28th August 2011, 08:25 PM   #6
I'm using a Coke-bottle shaped 6BY5G as a rectifier in my SE amplifier.
Works quite well, and doesn't cost much $$ either.
Steve
Old 28th August 2011, 09:24 PM   #7
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Looks like they withstand a lot more capacitance than most rectifiers, so better filtering as well. Although a downside is larger current spikes to charge the caps which puts more harmonic distortion back on the mains.
Old 29th August 2011, 10:36 AM   #8
that brings me to another great tv tube . its a driver for CTR's has very high ma/v its still avalable for 1/4 of the cost of a new 12ax7
now im not gona say the name . out loud course supply is limited and to avoid the crazies buying em all . but if you figure your lucky
oh yeah i took one apart . its crazy build . everything hard metal gold plated and then carbonized . and after serving in a TV it looked like it took a heluva beating
kudo's if you know what im talking bout .
Old 29th August 2011, 12:48 PM   #9
работник
You might be thinking of the lovely PL802 with its extraordinary 40mA/V.
But the IF pentodes are as good sounding as any valve:, EF8x EF18x, 6F2x, 30F5
Connect in shunt cascode, and get wonderful sound, gain of 300 - 400.
Old 29th August 2011, 01:15 PM   #10
hmm dont forget the junkbox pcf types might even be usefull .
these are avalavle in abundance
TV Horz. Output Tubes used as Output Audio ppl Tubes / Valves 90 27th August 2009 02:21 PM
211/VT4C test data for TV-7 / TV-10 Doctorcilantro Parts 0 24th October 2008 06:41 PM
Horizontal TV tubes used in amplifier? MGH Tubes / Valves 40 1st April 2007 07:33 PM
Help valve newb salvage some old TV tubes mr_push_pull Tubes / Valves 17 21st October 2004 12:14 PM
Page generated in 0.12075 seconds (80.44% PHP - 19.56% MySQL) with 10 queries
