| diyAudio Sponsor | ||
I see this phras used a lot by tube sellers. Unless I missed something it's not in typical tube data.
Where can I find this value for various tubes.
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie. |
#2 |
"phrase" Sorry
#3 |
Gm is the Transconductance and will be in the tube's datasheet....
Das Beste Oder Nichts |
#4 |
#5 |
I think thats the prob here!
Too many names/acronyms for the same thing!
#6 |
Thank you your input. I'm aware the data sheets include a Gm value. I think this value for a new tube in good condition. When I calculate the Gm from the curves it is usualy about the same as the data sheet.
Again, what I'm looking for is the Minimum Acceptable Gm. I would assume this would be something less than the data sheet value.
#7 |
I guess it depends on the circuit. As a broad generalisation lower Gm results in higher noise, higher output impedance and lower gain, so it depends how much of these attributes you can stand to lose in a particular application.
#8 |
Usually 20% loss was accepted as end of life.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#9 |
I'm with Wavebourn on this. I gave up decades ago on commercial tube testers, and developed my own testers with regulated voltages for all elements that let me test under published operating conditions. That way, there are known standards to test against. But also, I had to develop my own "English" scale along the way to translate the results into a practical rating of condition. On the tubes that I test using Gm as an indicator, I accept 90% or better of published value as "Good", 80% < 90% as "Weak" and below 80% as "Bad".
Dave |
#10 |
Some new valves may be only 80%. I would say below 70% is bad.
| How much noise is acceptable? | matherp | Chip Amps | 10 | 4th December 2010 04:56 PM |
| Acceptable Acceptable Load for Lite 60 DAC 6922 Output Tubes | dtm1962 | Digital Source | 0 | 14th November 2010 01:03 AM |
| Where can i find Pioneer gm-x624/gm-x524 manuals? | gudrun | Car Audio | 1 | 22nd February 2007 02:01 AM |
| Acceptable F3 | UNDERSTANDIN | Multi-Way | 0 | 21st September 2005 03:23 PM |
| Page generated in 0.09529 seconds (78.96% PHP - 21.04% MySQL) with 10 queries |
