| diyAudio Sponsor | ||
Hi all,
I've been given the makings of an EL34 PP amp - chassis, valves, iron etc. But I'd like to try a different driver stage. I've got about 500V of B+ to play with, good current capability and enough heater current to run the 4 EL34s, 2 x 12..7 and 600-800 mA of 6.3V heaters. Although I do have other Tx I could add in if more current is needed for heaters. Could someone point me in the direction of a good sounding EL34 PP amp? Something with 6SN7, 6N2P or the 12..7 series would be an added bonus!! I have searched, but its very hard to figure out what sounds best.... Fran
Visit www.tirnahifi.org!! |
#3 |
toroidal output iron is the kind..... and I don't have other spec's than the fact that they were used for EL34s. I suppose I could also put in KT66s or maybe even KT88, but I thought KT88 would need a bit higher B+ (+ more heater)
So, the long way round is that I'm kinda committed to EL34 unless a good argument is set up for something else!! Fran
#4 |
Impedance would be an important thing to know.
If I were sticking to tried and true output tubes, I'd be inclined toward 6L6GC in class AB2, which will get you 50-60 watts easy, and excellent 6L6GC are available dirt cheap.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
"different driver stage" - different from what?
You could do a 5-20, although opinions vary about how much this needs to be modified. |
#6 |
Do you have UL taps? Here's one with a Mullard style circuit.
http://www.lundahl.se/pdfs/claus_byr...fier_30wpp.pdf There are many Dynaco ST-70 circuit's out there too that might work great. Some are Williamson types. Depends on your OPT's what you use. |
#7 |
The existing amp is an old KEL34 from world audio designs... see the attached PDF for the sch. Its mostly built on a PCB, so I suppose I was looking for something to play with that would be an improvement on that....
#8 |
My vote would be this, using original ST70 iron or anything reasonably close in primary impedance. Very pleased with the sound. 500V sounds a tad rich for me, but you could go with cathode bias. My preference is strongly toward triode connection; I don't bother with the UL switch.
Take what you like and spit out the bones. |
#9 |
Zigzag: I take your point and agree, but I already have a st70 running kt66s and was going to go for something else. The st70 does sound lovely driving my quads....
Fran
#10 |
There's always the old Linear 30 watt circuit here Linear Conchord 30w Amplifier . I can verify that does sound nice as I used to have two back in the day.
| EL34 SE triode mode A class sch wanted | trancy | Tubes / Valves | 14 | 10th January 2008 10:16 AM |
| Good sounding 6V6 PP UL driver circuit? | SHiFTY | Tubes / Valves | 20 | 30th April 2007 11:34 AM |
| Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? | ray_moth | Tubes / Valves | 4 | 23rd February 2007 12:22 PM |
| Is this a good choice for El34 PP | dstockwell | Tubes / Valves | 5 | 14th July 2005 06:52 PM |
| Page generated in 0.10521 seconds (75.60% PHP - 24.40% MySQL) with 11 queries |
