Old 26th August 2011, 09:09 PM   #11
vinylkid58's Avatar
Originally Posted by woodturner-fran View Post
toroidal output iron is the kind..... and I don't have other spec's than the fact that they were used for EL34s. I suppose I could also put in KT66s or maybe even KT88, but I thought KT88 would need a bit higher B+ (+ more heater)
Maybe give one of the KT88 PP blocks a try. It's a big thread thou:
"Mullard 5-20 KT88 PP blocks!
jeff
Old 26th August 2011, 09:25 PM   #12
tinitus is offline tinitus  Europe
I've got about 500V of B+ to play with, .....
Fran
from what I have read, some older EL34, and it equivalents, takes the higher voltage better than new ones
and also better than KT88
don't much about tho
Old 26th August 2011, 09:41 PM   #13
diyAudio Moderator Emeritus
Bas Horneman's Avatar
How about PP2C? Designed by the late Allen Wright. He used to mail (the schematic) it to everyone who asked him for it.
Or the PP1C which uses EL34. Later on Allen added as CCS in the output stages as well. Apperently with positive results.
Old 26th August 2011, 11:55 PM   #14
The PP2C looks interesting indeed.... I've gone back to ask about the impedance of the OPT, but given as it was made especially for a PP EL34, I'm guessing that the impedance should be about right.
Many thanks for all the suggestions so far!! Is there a thread somewhere about the PP2C? - a search didn't throw up anything...
Fran
Old 27th August 2011, 12:21 AM   #15
frugal-phile(tm)
planet10's Avatar
PP2C was originally developed for an ST70 donor. Issues may be providing sufficient heater current (but this amp really deserves an indendent heater supply) and a shunt reg is mandatory on top of the cascode LTP.
My buddy is building one of these and i am gathering parts for an EL84 derivative.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th August 2011, 11:25 AM   #16
cjkpkg is online now cjkpkg  United States
Here is another one from tubecad journal
I have built the PPEL84 circuit in this post and it is a terrific amp...I have plans to build this EL34 amp someday....
Old 27th August 2011, 12:04 PM   #17
Hi cjkpkg,
I can't believe you posted that!! I also built that EL84 amp - its a stunning amp!! Thats the one I'll build - nice winter project!
Thanks a mill for the heads up and everyones suggestions!
Fran
Old 27th August 2011, 01:09 PM   #18
Yes indeed...the EL84 amp is quite a nice little setup. I may start collecting my iron for this one as well. I have been wanting to build a higher power tube power amp in a more contemporary enclosure chassis. Like a HiFi2000 3U if it could fit or maybe a 4U if height dictates. The P2P + EL34 height will dictate that. A hammond 10X12 bottom plate should work nicely with a few bends in it....
Power Xformer
OPT's
Old 27th August 2011, 02:16 PM   #19
I would also like to experiment with an LED bias scheme for the first triode input in lieu of the cathode resistor. This worked wonders on the EL84 amp.
Another interesting approach would be a CCS on the EL34's. I am running 80mA per channel on an LM317 on the EL84 as well.
Old 27th August 2011, 02:17 PM   #20
boywonder's Avatar
Default If you want triode....
There's also Poinz' 6GK5/EL34 Music Machine. Triode, Fixed bias, CCS under the LTP, very straightforward design...about 12-14W or so.
The power supply in my MM is a fairly conventional CLC.....
Required OT impendance is 5K.
EL34 SE triode mode A class sch wanted trancy Tubes / Valves 14 10th January 2008 10:16 AM
Good sounding 6V6 PP UL driver circuit? SHiFTY Tubes / Valves 20 30th April 2007 11:34 AM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
Is this a good choice for El34 PP dstockwell Tubes / Valves 5 14th July 2005 06:52 PM
Copyright ©1999-2013 diyAudio
