I have two old/used EL34 in my SimpleSE amplifier. They are in full working condition and I would like to buy a new set of the same...
The problem is that I can't identify them as most of the printing is gone. I can't attach a photo at the moment, but I can give some clues:
1. The base is medium brown
2. The printing is white
3. Central on the tube the line "EL34/6CA7" is printed
4. Above the type printing something has been printed, perhaps a logo or something. Perhaps a print with more than 1cm diameter..?
5. On the base a small label has been places, it is brown with two white windows: "Grade:" and "Measured by:"
Anybody with a clue?
Hi, possibly Dutch Philips Miniwatt. If they are there should be etched in the glass bulb just above the base a batch# and factory id.
e.g. X14
L1G
A Google search for EL34 will bring up sites with photos of various manufacturers products.
Steve.
Ok, thank you...I will check that later today!
Regarding Google search...I have spend some hours searching....and found nothing looking like mine!
Refer to this website for manufacturer and date codes: Mullard, Philips, and Valvo Tube Codes
These are looking very close:
But I don't think there is that narrowing of the glass tube just at the base?
THe 'proper' St Petersburg EL34 is brown base, with characteristic legend:
EL34 Svetlana =C=
THe B version Shuguang also has brown base:
Vaccum Tune Shuguang EL34-B - EL34 Tube @ on9mart.com
The JJ and Electroharmonix versions always have black base, so far as I have seen.
If it's not one of the first two, it's probably out-of-production - and for EL34, this means very high cost, since guitar amps use them.
EL34 Svetlana =C=
I have a few photos, but now I must find out how to put them here....
imgur: the simple image sharer
Make sure they're not blurry pictures because those are useless. We have to be able to see every detail.
please use forum upload
save your resized photos in your document files
when posting, click on 'manage attachments', below post
moderation
- Tubes / Valves
- Identifying EL34 tube?
