diyAudio Sponsor
Old 28th August 2003, 04:15 PM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Default rec. for creative ideas for alternative tube amp chassis
some of us have to(or may even prefer to) make do with what's available as far as tube amp chassis go.
while i've seen the usual ideas for using surplus computer or printer chassis, biscuit tins and various other suggestions on this board, ..i thought it would be interesting to have a thread where people put forward their suggestions for alternative chassis which could work
thanks, vin
Old 28th August 2003, 09:50 PM   #2
zix is offline zix  Sweden
zix's Avatar
Default how ībout cardboard?
Ideas...
Sometimes shoeboxes look really good. Sic!
And, compared to tin boxes and the like, cardboard is a lot easier to make holes in. Since the shoebox probably already sports a well designed lid youīll enjoy easy access to your components for changing things, which is great in a developing DIY project.
If the cardboard isnīt steady enough, you could use wooden crossbraces as supports for tubes, transformers and big capacitors.
That sheet metal with lotsa holes in it, whatever itīs called, might be good for DIY work too. Maybe you could use it as a kind of ground plane - by using small screws in the holes of the sheet and connecting/fastening component leads directly to the sheet with īdem screws. This would make it possible (but not necessarily easier) to change the ground layout, which is important in RIAA amps and the like. The "hole sheet metal" piece could be mounted on top of or in the middle of any wooden box with the same, or slightly larger, size.
Really, I am just throwing ideas out to you. Catch if you like!
Old 28th August 2003, 09:57 PM   #3
r0cket- is offline r0cket-  United States
Default Re: rec. for creative ideas for alternative tube amp chassis
thanks, vin
This is in the same vein as computer chassis, but I think an external SCSI box of some sort would work. The ones designed for 5.25" CD-ROM drives and the like are probably just the right size for a modest tube amp. Just drill/cut out the top of the chassis for the tubes/caps/tranformers. I'm not sure about refinishing the box, but it could probably be done, or wood sides could be built around it.
Old 28th August 2003, 10:11 PM   #4
zobsky's Avatar
Default Re: how ībout cardboard?
Originally posted by zix
Ideas...
i can just see it now "nike (TM) high performance tube amp"
seriously though, i have used a thin sheet of particle board before, ...keeping it stiff though is not that easy, unless you brace it. also not a good long term to use a cardboard box solution in view of fire hazards
the perforated metal idea seems interesting
i have also used a printer distributor box. very often in surplus stores, you will see a bunch of commercial grade non-working network router boxes, and other arcane equipment going for just a buck or so. these are sometimes built really tough and better than many raw chassis, if you are willing to be creative and utiilze them.
thanks for your replies, keep em coming.
Old 28th August 2003, 10:14 PM   #5
diyAudio Senior Member
fdegrove's Avatar
Use anything you like but keep it safe and also consider shielding from RFI and EMI.
Frank
Old 28th August 2003, 11:31 PM   #6
zix's Avatar
Fabulous! Smallish 7/8 port switches/hubs could be used for line and RIAA amps. If you cover the diode happy front with a wooden frontplate or something itīll probably look great!
And the RJ-45 contacts arenīt all that bad, are they? I mean, theyīre already mounted and all... And CAT-5 cable is supposed to be great for audio cable. Or was that for speakers?
Old 28th August 2003, 11:52 PM   #7
Default more ideas
marble or granite tile would make a nice top surface. you can buy special bits or cutters to cut small holes in tile for the tubes and transformers.
mirrors are also nice, if a bit shiny.
you can find old perf metal covers from e.g. Dynaco amps on ebay for not too much.
a 'shadow box' style wooden frame could be used for the walls of the chassis, if you have an old one around. (or buy a new one - they're already finished and joined.)
any premade metal box could be interesting - how about a retro lunchbox? scooby-doobie-toobie, anyone?
or for that matter - find an old tube radio, gut it, and use that enclosure. instant deco box - bakelite, plastic, wood.
a nice cigar box...
/andrew
Old 29th August 2003, 12:07 AM   #8
My passive linestage now sits in a cigar box:
I wouldn't recommend this for tube circuits though, because of the heating/fire issues. I considered cardboard and wooden boxes for my tube amp, but ultimately ended up with a boring aluminum box just for peace of mind.
Old 29th August 2003, 12:10 AM   #9
pretty.
Old 29th August 2003, 12:16 AM   #10
Send a message via AIM to travis
go to the army navy surplus store and get one of those ammo boxes?
donuts
Ideas for SE amp with this tube Pentium100 Tubes / Valves 13 14th December 2011 02:21 PM
Little Dot MKIII, faulty driver tube, GE5654 alternative in the UK? markiemrboo Tubes / Valves 6 6th November 2007 11:34 PM
Need project ideas to fit this chassis taj Solid State 62 6th April 2007 06:53 AM
Chassis Ideas llmobll Chip Amps 30 7th March 2007 06:10 AM
Prototyping ( Breadboard ) Chassis Ideas and Suggestions DrDeville Tubes / Valves 4 31st March 2004 07:46 AM
Page generated in 0.14476 seconds (81.69% PHP - 18.31% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
