| diyAudio Sponsor | ||
I have a SE 2A3 amp with choke loaded (150H) 6J5 drivers. The sensitivity is around 2Vrms. I would like to get this down to about 1Vrms. A friend suggested using line level 1:2 Tx's at the inputs.
Morgan Jones doesn't address the topic so I'm lost. Will this work? Where can I find design/application text? Where can I get the Tx's? Or....any comments or suggestions. Thanks
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie. |
#2 |
Try the amorphous Lundahl LL1676. Great transformer! But you should go 2:1, not 1:2!
Brgds Lars |
#3 |
1:2 sounds about right to me. You want to step the voltage up from 1V to 2V, so the amp is more sensitive, correct?
#4 | |
se |
#5 |
Hammond 560Q is good and fairly priced:
Hammond Mfg. - Broadcast Quality Audio Transformers - (560, 800-844 & 850 Series) |
#6 |
Sorry, missread your post. In this case, note input impedance will be lowered 4 times.
Brgds Lars |
| trouble matching line level to guitar amp input level...any help? | mondogenerator | Tubes / Valves | 5 | 19th December 2009 10:00 AM |
| speaker level input vs line level question | crippledchicken | Subwoofers | 4 | 17th July 2007 03:36 AM |
| Can I split line level input? | dublin78 | Chip Amps | 15 | 14th February 2007 03:43 PM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| How do I connecting speaker signals to line level input ? | ANALOG GUY | Car Audio | 1 | 17th April 2006 07:42 AM |
| Page generated in 0.08342 seconds (76.18% PHP - 23.82% MySQL) with 10 queries |
