diyAudio Sponsor
Old 24th August 2011, 10:05 PM   #11
Default BO-14 pics
Old 24th August 2011, 11:19 PM   #12
Default BO-14 pic
Old 25th August 2011, 10:42 AM   #13
Originally Posted by HollowState View Post
I'm not sure if I have the artical you're refering to or not. I have so many papers and magazine articals stuffed in a file cabinet draw that I haven't looked at in years. I do remember an artical in one of the vintage magazines I have a tall stack of that used the BO-14 with PP 6BG6s. I think it's a "Radio & TV News" from the late 50's or early 60's. But if you have the artical, post it or send it to me through the forum. I'd enjoy seeing it.
Victor
Victor,
Send me an email and I'll send you *AN* article on a BO-14 design. It is a few pages of pdf's and uses the iron line up mentioned in this thread.
I have a pair of these too, and a set of the HV power trans-es and chokes. Not sure I'll do it as written; no need for a 100W amp. Lower B+ for Class A operation is much more appealing...
cheers,
Douglas
the Tnuctipun will return
Old 26th August 2011, 06:55 PM   #14
I did some checking and the amps are wired in triode mode. Power supply is choke input. Still have more to do before running them. Wish I had more time and energy!
Old 15th October 2011, 05:37 PM   #15
I'm thinking of rebuilding this bunch of iron to the original Ken Olson specs, probably as a triode amp. Also considering using a board like Pete Millet's 5687. Any advantages to other input stages or is the original best?
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. Buckeye Solid State 48 26th May 2012 07:06 AM
Bo Bengtsson goes extreme peranders Planars & Exotics 10 17th October 2009 06:07 PM
Evolve Amps 100W+100W Stuff 4 Sale WALTER BURKHARD Swap Meet 4 8th June 2005 10:57 AM
FS-BO, Dynaudio D-54, Focal 5N412 DBL apassgear Swap Meet 1 28th September 2004 06:37 PM
Chicago Standard BO-14 100W outputs dshortt9 Swap Meet 1 10th August 2004 04:25 AM
Page generated in 0.09828 seconds (69.36% PHP - 30.64% MySQL) with 11 queries
