Approaching the best primary impedance on low or high side? - Page 2 - diyAudio
Old 24th August 2011, 08:41 AM   #11
jule is offline jule  Slovenia
For class A operation on 250V they recommend 43mA, for AB 34mA. So I only lower the current and I am in other operation?
But how do I find the power output? What will I have to measure to approximate?
Old 24th August 2011, 01:37 PM   #12
current x HT voltage will give you a rough guideline.
Old 24th August 2011, 01:39 PM   #13
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Measure the RMS output voltage just before clipping. Then P=E*E/R where E is rms voltage, R is your load impedance and P is power.
RMS = Peak to Peak /2.83
Old 24th August 2011, 01:45 PM   #14
isnt RMS = peak to peak/root2
Old 24th August 2011, 03:30 PM   #15
TheGimp's Avatar
Peak = p-p/2
RMS = Peak/root2*
* only for sine waves
Old 24th August 2011, 04:40 PM   #16
If I use sine wave generator as input signal, then I use root^2. Tomorrow I will probably build the amp and try it out.
Delay matching in IR2xxx low and high side gate drivers Eva Power Supplies 8 10th June 2007 08:02 PM
High And Low Side Phototransistor Opto Mosfet Driver medogrizli Power Supplies 2 1st June 2007 12:51 PM
High/Low Impedance speakers Okie Multi-Way 22 6th January 2007 02:35 AM
Low side driver as a High side fr0st Parts 0 8th May 2004 02:14 PM
High impedance out amps VS as low as possible. Brian Guralnick Solid State 57 31st October 2002 07:47 PM
Copyright ©1999-2017 diyAudio
