| diyAudio Sponsor | ||
I was ready to buy a matched quad of JJ 6L6GC power tubes when I noticed a lot of dealers selling burned in JJ's for 5 dollars more. Seems like a good deal but I figured I'd email JJ to see what they thought about it. They said they already burn them in at the factory so there's no need to pay extra. I emailed some dealers to ask what their burn in is process but never received any replies. Any thoughts on this would be appreciated.
#2 |
Any maker worth their salt burns their tubes in. It's a necessary part of the manufacturing process. And I strongly suspect some do a better job then others. The better dealers will also process output tubes with a further burn in. Perhaps not to simply use it as an advertizing or sales advantage, but to assure themselves that the tubes they sell will hold up. Having to replace tubes that fail prematurely is a drag on business. But for either reason, it's a win-win situation.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 | |
#4 |
I don't believe manufacturers "burn in" all tubes on a scale that demand requires........too much time sucked up on the soak rack and alot of electric....all overhead costs everyone is longing to cut back......so perhaps 1 out 10 and do the stat analysis.
When asking a vender about "burn in"; mention the approx operating conditions of tube(s)....also mention to "tap test". There is a proper impact gforce for this.. I found it's worth it esp B9A (microphony) and Int oct power types...where premature failure shows up pretty quickly. Some will remember the earliest 1990 Chinese KT88 and other Sino clones produced some of the brilliant fireworks when tapped, many fell into the trap of putting these tubes directly into amps which were inbuilt within the loudspeaker cabinets, the resonance doing a perfect destruction of the tubes plus alot of circuit damage. richy |
#5 |
FWIW, I read about the JJ quality control is non existent. Anyone have any additional opinion??
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average. |
#6 |
I always purchase power tubes matched and burned in - the matching having occurred after 24hrs of burn in minimum. This process also IMHO reduces problems with infant mortality, and with reputable vendors usually results in tubes that remain reasonably well matched over their life time. (Not always the case)
The manufacturer being discussed has been much maligned lately for poor quality product wrt octal based power tubes and poor QC practices in general.. I'd be particularly leery purchasing power tubes of any brand without further burn in and testing by the seller. Most of the higher volume producers appear to have variable quality over time. I've had bad experiences with nearly every manufacturer currently making tubes. Caveat Emptor! YMMV, and all above is just my opinion - speaking only for myself.
www.kta-hifi.net |
#7 |
I bought a matched quad of JJ 6CA7's in 2010, they are fine. Great, since the alternate source pays taxes to an oligarchy. Since the boxes were marked with a number, perhaps the manufacturer did the matching.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 Last edited by indianajo; 23rd August 2011 at 04:45 PM. |
#8 |
I suppose another 5 dollars is worth it as long as the dealer burns them in further. I didn't find out how long a period JJ burns them in but they claim they match them for GM and Plate current. I have a set of 8 JJ EL84's in my Peavey 50/50 for over a year and they are ok and sound great. I'll have to contact the dealer and see how much longer they burn them in for.
#9 | |
Regarding vendors burning in tubes - infant mortality is the #1 problem with tubes, so any rational steps taken to minimize it are worth doing. I don't charge any extra, but that's me - what others do is up to them. I think Kevin's post above is pretty much right on target. |
#10 | |
| NAD 502+512+514 - Burned Transistor from Focus Power Buffer Output Stage (pos. Half) | tiefbassuebertr | Digital Source | 0 | 28th July 2011 04:40 PM |
| @#$^!! Burned out power amp | Dave Jones | Solid State | 1 | 14th January 2011 09:40 PM |
| Burned out power tube | fauxpas | Tubes / Valves | 14 | 26th January 2008 07:32 PM |
| Power Tubes | s2kov | Tubes / Valves | 6 | 18th November 2004 09:23 AM |
| I burned my Aleph 3! Please help! | Jesse | Pass Labs | 25 | 26th October 2003 01:56 PM |
| Page generated in 0.12411 seconds (82.89% PHP - 17.11% MySQL) with 10 queries |
