diyAudio Sponsor
Old 21st August 2011, 03:19 PM   #1
pof@ is offline pof@  Denmark
Default KT90 to KT88 with autobias
I have a SE amplifier running KT90.
The builder tells me that due to the auto bias system it should be able to run KT88 as well. But whatever autobias circuit he has used I guess it will always try to reach the same particular bias current no matter if I put in a KT90 or a KT88.
Are the two tubes so similar so this doesn’t matter?
My idea was to make a schematic from looking inside but this is not easy at all after first look.
Old 22nd August 2011, 06:18 AM   #2
Tinkerer
No, autobias is a negative feedback mechanism. It reacts to cathode current. So the bias will be OK more or less when you install KT88.
Old 22nd August 2011, 06:22 AM   #3
Will the bias be the same for KT88 and KT90? I think it will?
Old 22nd August 2011, 06:24 AM   #4
Tinkerer
No, and it does not have to!
Old 22nd August 2011, 06:33 AM   #5
Seems like I need some basic knowledge on autobias. Is there anyone who can give me a good explanation?
Old 23rd August 2011, 09:51 AM   #6
Skorpio is offline Skorpio  Denmark
Auto bias is just as simple as a resistor in the cathode. It will mate within some limits to different tubes...
Try to look at Tubelab.com, there you will find examples of designs using a variaty of tubes...
K120 on 6550/KT88/KT90 anyone tried??? salajazz Tubes / Valves 10 3rd July 2011 08:28 AM
From KT90 to KT88 ManUtd Tubes / Valves 36 12th March 2011 07:52 PM
KT88 vs. KT90 bench test richwalters Tubes / Valves 4 23rd December 2004 11:19 AM
Autobias for 6L6/EL34/KT88 SWMoore Tubes / Valves 10 2nd April 2003 07:26 AM
Page generated in 0.08526 seconds (72.49% PHP - 27.51% MySQL) with 10 queries
