diyAudio Sponsor
Old 18th August 2011, 09:48 AM   #1
nige838 is offline nige838  United States
Default If I change B+ do I have to change the circuit?
If I change B+ do I have to change the circuit? I'm interested in lowering a plate volatge on a AX7 from around 275 down to 160-170 volts. should I worry about altering the circuit?
Old 18th August 2011, 10:07 AM   #2
DF96 is offline DF96  England
Yes, although it depends on what the circuit is supposed to do. If a guitar FX box you will just get slightly different FX. If a hi-fi preamp you will get a bit less gain and a lot more distortion. 12AX7 like a high resistance in the anode circuit, which means either high HT/B+ or an active load.
Old 18th August 2011, 11:00 AM   #3
Thank you for your quick reply. would the changes be in the power supply or in the amplifier circuit?
thanks
Old 18th August 2011, 11:16 AM   #4
In the circuit. Why do you want to power a circuit from the wrong voltage?
Change of circuit from triode to tetrode richard8976 Tubes / Valves 21 25th October 2010 07:26 PM
name change Juergen Knoop Forum Problems 2 25th October 2007 08:50 AM
How Would You Change This Soildstate Circuit To Tube prorms Tubes / Valves 5 21st October 2007 10:01 PM
change the SMPS circuit in car amplifiers. + picture Astro Power Solid State 32 3rd August 2005 11:35 PM
Heater voltage circuit change......why please frank2395 Tubes / Valves 5 25th May 2005 11:33 AM
Page generated in 0.07107 seconds (70.26% PHP - 29.74% MySQL) with 10 queries
