| diyAudio Sponsor | ||
Hi, I like to copy this RIAA amplifier for mm
http://www.dddac.de/pics/phonodude/pd-circuit2.gif Since I can not source 5755 tube may I use 6N9C instead, which is electrical equivalent of 5755. I will be most obliged if someone knowledgeable confirms. Regards |
#2 |
try ebay.. " 5755 tube " and you will find enough.
#3 |
why you dont use "ECC83" its more common and easy to find, recently i made a experience with ecc 81 and its sounds very nice.
| Phonodude problem | Miniwatt | Tubes / Valves | 10 | 30th August 2011 09:01 AM |
| Phonodude question | w00t | Tubes / Valves | 0 | 8th November 2008 07:17 AM |
| Page generated in 0.06514 seconds (69.31% PHP - 30.69% MySQL) with 10 queries |
