6CM7 another tube in disguise?
Old 29th August 2003, 03:20 AM   #21
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Default figure 11 scan
Old 29th August 2003, 03:42 AM   #22
Default not a snivet less or a skosh more!
now how much is a snivet anyway? or a skosh?
Thanks all!!
Old 29th August 2003, 03:53 AM   #23
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Re: not a snivet less or a skosh more!
Thanks all!!
http://www.onlineconversion.com/ finds nothing on the search.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 29th August 2003, 08:48 AM   #24
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Twas nearly brilig...
Wow! Figure 13 is a curve to conjure with! Was there a caption to go with the final illustration, and is it mirrored from left to right? I can see hum burs with perhaps RF on them, and also the vertical disturbance which I was expecting to see on the LHS.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th August 2003, 03:53 PM   #25
Default figure captions
captions for figures:
Fig. 11 Typical Examples of Snivet Interference
Fig. 12 Horizontal-Deflection-Tube Plate Characteristic at Zero- Bias Voltage
Fig. 13 Load Line of a 25CD6-G Horizontal-Deflection Tube in a Receiver That Exhibits Strong Snivets
I would guess that figure 13 is for a flyback design so SE.
Have been told by a golfer that a snivet is likely just a small divot!!
Old 29th August 2003, 04:17 PM   #26
Default house of mirrors
Oh! I see what you mean, Figure 11. I am surprised to see the streak on the right side too, but that was how it was printed in the book. Images are too different examples I think. Here is a re-scan of figure 11 (left side) with more resolution: (really needs grayscale image to do it justice, but too big a file)
Old 29th August 2003, 04:21 PM   #27
Default more fig. 11
and here is Fig. 11 right side:
Old 29th August 2003, 04:51 PM   #28
EC8010's Avatar
Default Snivets, strangeness, and charm
Thanks for the captions and the bigger images, The bigger image shows that it can't be mirrored because the flyback lines slope in the right direction. Weird.
Old 29th August 2003, 05:12 PM   #29
Default quarks and snivets
Ah! Quarks and Snivets, of course!
A snivet must be a quantized something or other.
Maybe its the smallest possible GREMLIN that can get into electronic equipment. No wonder it was so hard to get rid of them.
Probably cause distortion too. Now, are their left handed and right handed ones, and how do we get rid of them? Probably why someone invented CHARM!
Old 29th August 2003, 05:56 PM   #30
EC8010's Avatar
Default Where are the physicists?
Seriously, quantum mechanics probably are required to explain snivets.
Perhaps Fig. 13 is actually a rare cloud chamber track of a snivet, and its refusal to obey Newton's laws is direct evidence that it is a member of the gremlin group of sub-elementary particles.
6CM7 another tube in disguise?Hide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
Transformers (doughnuts in disguise?) mcai7et2 Parts 8 26th January 2003 02:26 PM
Copyright ©1999-2017 diyAudio
